Nvidia shield remote reprogram
The shield-remote has buttons for volume-up and volume-down. I would like to trap these commands, and use it as a trigger for an automation which controls the volume of my AV-receiver.
The script for controlling this volume is easy, and is working.
How can I trgger this script? I have tried something like this:
  - platform: event
    event_type: call_service
    event_data:
      domain: androidtv
      service: androidtv.adb_command
        entity_id: media_player.shield
        command: VOLUME_UP
It looks as if the androidtv.adb_command is not a service?
anyone a solution?
André
hey André. Awesome that I found your thread here.
I had similar plans. In my case I am thinking about to connect my remote with bluetooth to my homeassistant and let him send the commands to a device I want.
The background:
nvidia had a nice hardware but no plan howto integrate that in the real world. I own the newest remote. This one
For example: I am able to setup the ir device, my tv, on the shieldtv but I can not change tv-channels after switchting to the tv-mode.
Your problem. Can you explain how you would like to get the “BUTTON_PRESSED” event from the remote?
And is there a reason why you do not use the internal ir-function on the remote?
Hi JamieMe,
I think I made a mistake by assuming the buttons on the remote trigger an androidtv.adb_command.
They cause an action on the shield and trigger nothing in HA.
Only the vol-up en vol-down act different, they send an IR-signal. This signal can be used for conventional IR-operated electronics.
So I am on a false track!
The reason I don’t use the IR-function on the remote is simple. The AVR is placed not in sight.
I am planning to use a broadlink transmitter. This can be integrated with HA. Maybe I can trap the Nvidia remote ir-signal in HA.
André
what is about a IR extender:
Cable Matters Câble d’extension pour télécommande Infrarouge, Cable Répéteur IR - 3 mètres : Amazon.fr: High-Tech
Cable Matters Infrarot Fernbedienungs Verlängerungskabel 3m - IR Empfänger USB Kabel 3 Meter: Amazon.de: Elektronik & Foto
And just to get a mind of your area. Is your Homeassistant device near your tv-area?
This topic is old but I have this problem because my PRIMARE preamp is not compatible with TC Shield IR commands and I am looking for a solution with Home Assistant
