NWS Alerts how to get alert not just count
I have installed this HACS device called NWS Alerts to give me access to NWS weather alerts. It produces a numeric value that equals the number of active alerts. If you look at its attributes, you see the text of the alerts in a not very user-friendly format.
Is there some other device I can use to display the actual alert text on a dashboard? If not can someone point me to an example of how to write a python script to extract and format the attribute info for display on a dashboard?
A markdown card with a template.
I believe the alert text is an attribute when there is one active. It pretty bizarre that this isn’t mentioned in the documentation. Anyways, you can get all kinds of information directly from the NWS with a bit of study and the RESTful integration. The NWS forecasts are better than whats available from the various HA weather integrations.
OK I’ve found some info on how to do templates. Looks pretty straightforward. But the one I saw just gets the attribute text. For this device the text looks like this:
- Event: Winter Weather Advisory
URL: >-
https://api.weather.gov/alerts/urn:oid:2.49.0.1.840.0.e7aa5e0f16df9a0e7e0bd54d02befd197bcc48bb.001.2
Headline: >-
WINTER WEATHER ADVISORY IN EFFECT FROM 3 PM THIS AFTERNOON TO 5 AM MST
SATURDAY FOR ELEVATIONS ABOVE 5000 FEET... ...WINTER WEATHER ADVISORY IS
CANCELLED
Type: Alert
Status: Actual
Severity: Moderate
Certainty: Likely
Sent: '2025-03-14T02:07:00-07:00'
Onset: '2025-03-14T15:00:00-07:00'
Expires: '2025-03-14T15:00:00-07:00'
Ends: '2025-03-15T05:00:00-07:00'
AreasAffected: Mazatzal Mountains; Pinal/Superstition Mountains; Southeast Gila County
Description: |-
* WHAT...Snow expected for elevations above 5000 feet. Total snow
accumulations between 4 and 6 inches.
* WHERE...Mazatzal Mountains, Pinal/Superstition Mountains, and
Southeast Gila County.
* WHEN...From 3 PM this afternoon to 5 AM MST Saturday.
* IMPACTS...Travel could be very difficult. The hazardous conditions
could impact the Friday evening commute.
Instruction: |-
Slow down and use caution while traveling. The latest road
conditions for the s
tate you are calling from can be obtained by
calling 5 1 1.
Worse, yesterday when there were three warnings, they were just stacked on top of one another. At most I’d like to display the what/where/when and have it linked to the URL. Is there a way to parse?
@dzmiller I will have a look at what I can get from NWS, but this has what I need if I can find a way to parse it.
The RESTful integration will put the JSON into entities and attributes. Claude can help you with how to parse the one to many array which is the most complicated part.
It’s worth learning how to parse the JSON into entities as this is the standard API format. Learn it once and apply it everywhere. Also using Claude for things like JSON and regex is often good enough to feel like cheating.
But you will need to think about what data structure in HA you want with the alerts, which the integration author did not do. Nothing wrong with the way he did it, its just not particularly conducive for quality output to either the front end or voice.
@dzmiller well you were right that dealing with the NWS api looks like a better way of doing this.
For anyone interested, to get your local alerts you just query
https://api.weather.gov/alerts/active?point={lat},{long} (substituting your coordinates of course) and it returns a json string with the alert info.
What is going to be the challenge for me is that we don’t get a lot of severe weather where I live, so I will need to wait till we do and save the json so I can develop a way to use it.
OK here is the solution I’ve come up with. It is detecting No active alerts, so presumably it will detect active alerts too. Will have to wait until there is an alert for my area to know for sure.
Add to configuration.yaml (substitute your coordinates for {lat},{long}):
  - platform: rest
    name: NWS Weather Alerts
    resource: "https://api.weather.gov/alerts/active?point={lat},{long}"
    method: GET
    headers:
      User-Agent: "HomeAssistant"
      Accept: "application/geo+json"
    value_template: "{{ value_json.features | length }}"
    json_attributes_path: "$.features"
    json_attributes:
      - properties
    scan_interval: 900  # Updates every 15 minutes
And here is a markdown card to display results:
type: markdown
title: "NWS Weather Alerts"
content: >-
  {% set alerts = state_attr('sensor.nws_weather_alerts', 'properties') %}
  {% if alerts %}
    {% for alert in alerts %}
      **{{ alert.event }}**
      ā° Effective: {{ alert.effective | timestamp_custom('%b %d, %I:%M %p') }}
      šŸ”š Expires: {{ alert.expires | timestamp_custom('%b %d, %I:%M %p') }}
    {% endfor %}
  {% else %}
    āœ… No active alerts
  {% endif %}
For anyone that’s interested, I’ve refined a markdown card that prioritizes alerts, de-duplicates, and displays them on the dashboard. Special weather statements will provide a description of the weather; others only show the alert and expiration.
Code:
type: conditional
conditions:
  - entity: sensor.nws_alerts_alerts
    state_not: "0"
card:
  type: markdown
  content: >-
    {% set alerts = state_attr('sensor.nws_alerts_alerts', 'Alerts') |
    default([]) %} {% set priority_order = ['Tornado Warning', 'Severe
    Thunderstorm Warning', 'Flash Flood Warning',
                             'Tornado Watch', 'Severe Thunderstorm Watch', 'Flood Watch'] %}
    # āš ļø WEATHER ALERTS āš ļø
    {% macro render_alert(alert) %}
      {% set expires = as_timestamp(alert.Expires) if alert.Expires else 0 %}
      {% set ends = as_timestamp(alert.Ends) if alert.Ends else 0 %}
      {% set relevant_time = expires if expires > ends else ends %}
      {% set label = 'Expires' if expires >= ends else 'Ends' %}
      {% set time_remaining = relevant_time - as_timestamp(now()) %}
      {% set days = (time_remaining // 86400) | int %}
      {% set hours = (time_remaining % 86400) // 3600 %}
      {% set minutes = (time_remaining % 3600) // 60 %}
      {% set formatted_time = relevant_time | timestamp_custom('%-d %b %H:%M', true) %}
      ## **{{ alert.Event }}**
      > {% if time_remaining >= 86400 -%}{{ days }}d {{ '%02d' % hours }}:{{ '%02d' % minutes }}({{ label }}: {{ formatted_time }}){% elif time_remaining > 0 -%}{{ '%02d' % hours }}:{{ '%02d' % minutes }} Remaining
      > _({{ label }}: {{ formatted_time }})_
      {% else -%}
        _EXPIRED_
      {% endif %}
      {% if "Special" in alert.Event and alert.Description %}
      {{ alert.Description }}
      {% endif %}
    {% endmacro %}
    {% for event_type in priority_order %}
      {% set matched = alerts | selectattr('Event', 'equalto', event_type) | list %}
      {% if matched %}
        {% set most_recent = matched | sort(attribute='Expires', reverse=True) | first %}
        {{ render_alert(most_recent) }}
      {% endif %}
    {% endfor %}
    {% set others = alerts | rejectattr('Event', 'in', priority_order) | list %}
    {% for alert in others %}
      {{ render_alert(alert) }}
    {% endfor %}
  text_only: true
Here is an example output:
Thank you for this!
Thank you for this. I didn’t actually get it working correctly yet, but this is exactly what I was looking for.
Thanks. Mine doesn’t seem to be working so I will try this. One question: for the priority, where can I find a list of possible alerts? We don’t have tornados where I live but we have dust storms so I need to know the correct phrase.
Update: an almost complete list is here. For dust storms it’s ā€˜Dust Storm Warning’.
I have this working but two things:
  1. An alert just came through but the exact same alert is repeated four times. I’m guessing this happens because it’s checking periodically and finding the same alert when it does. Is there some way the script can check if an alert is already being displayed? I don’t know enough about YAML to figure this out.
  2. Also I’d like to ignore alerts that aren’t in my priority list. Do I assume correctly that I can do that by deleting that last block that starts with {% set others = alerts?
If you are in the East Valley like I am, I get about three to four alerts at certain times of the year. Weather, dust storms, polution level, etc. Mine duplicates as well because they keep sending them out.
Would you mind sharing your yaml. I would like to see what a setup looks like specifically designed for our area, where we very rarely have Ice and Snow storms.
Thanks for posting this. I was able to add this directly to my current dashboard.
I just have 1 question. Is there an easy way to get this to limit the returned results to the top 2 highest priority results?
Thank You, Thank you!!! I used your example directly! (This is way over my experience). My appearance is slightly different…any suggestion to have extra text not be displayed?
Thank you!!!
I got this at first too. Click on the ā€œShow Code Editorā€ and paste the code in there.
Thank you for posting this. My markdown card has been broken for the longest time. Worked perfectly.
Does your conditional work to hide the card when there are no alerts? I have tried this same code as well as a variety of potential alternatives and I cannot get the card to hide. It behaves the same with state: "0" and state_not: "0".
