I’m having issues getting the NWS integration to work. Installation seemed to go well, but when HA is started it can take up to an hour for the NWS sensors to lose UNKNOWN and show a value. I’ve tried different longitude and latitude pairs, no difference. I’d sure appreciate some help, thanks!
Check the HA logs. Do you see " 500, message=‘Internal Server Error’ " for your weather site? In my experience, NWS server has these errors very frequently, but eventually it goes away and the sensor values finally get updated.
I’m having the exact same issue, but it’s been ongoing for a week now. The service is becoming quite unreliable
I just updated to beta core 2024.7.0b0, and the NWS integration now seems to be working well.
FYI: I am using the Platinum Weather Card, and my YAML files are located here:
Just change the xxxx entries to the weather station you’re using and make sure there’s a path to the YAML files.
