This has been done via a HACS, but it wasn’t flexible enough for me. I have set up a system to push weather alerts from weather.gov to my phone via a persistent notification. I’m looking to improve this setup and would appreciate any input!
Change anything noted with CHANGE_ME
Limitations
- No Idea how well this handles multiple notifications
- The persistent message is cut off and wont show the whole message
Explanation:
Mobile Device Notification Group:
Defines a notification group named “Mobile Devices” that is used in the push notification automation. -
Weather Alerts JSON Pull:
- Sets up a REST sensor to pull weather alert data from weather.gov for specific zones in Phoenix.
- The User-Agent header follows etiquette guidelines from weather.gov documentation.
- Data is fetched every 5 minutes and stored as JSON attributes.
Weather Alerts Sensor Report:
Creates a template sensor that consolidates multiple attributes from the JSON data, such as areas, events, effective times, expiry times, headlines, message types, severities, certainties, and urgencies. -
Active Weather Alerts Count:
Another template sensor that counts the number of active weather alerts based on the JSON data. This is used for the automation. -
Automation:
- Triggers when there is at least one active weather alert.
- Sends a persistent notification to the mobile devices with details about the alert, including events, headlines, effective times, expiry times, severities, certainties, urgencies, message types, and areas.
Here’s my current configuration:
/homeassistant/configuration.yaml
# Mobile Device Notification Group
# This is used for pushing to multiple user devices. Not needed if you want to send to a single device.
notify:
- name: Mobile Devices
platform: group
services:
- service: mobile_app_CHANGE_ME
# Weather Alerts JSON Pull
# This is where I pull the information from to build the sensor that the alerts use.
- platform: rest
name: Weather Alerts JSON
resource: https://api.weather.gov/alerts/active?zone=AZZ550,AZZ548,AZZ543 #CHANGE_ME - Can be single or multiple zones
# Found on https://www.weather.gov/psr/Phoenix_CWA_Zones. Can also look here https://alerts.weather.gov/
method: GET
headers:
User-Agent: (HomeAssistant, Email@CHANGE_ME.com) # Etiquette defined on https://www.weather.gov/documentation. Should be (application, [email protected])
Accept: application/geo+json
scan_interval: 300 # Check every 5 minutes
timeout: 120
json_attributes:
- features
value_template: "{{ value_json['title'] }}"
# Weather Alerts Sensor Report
# This builds a single sensor with multiple attributes. Look at the sensor state for finding other alerts to poll.
template:
- sensor:
- name: "Weather Alert Sensor"
state: >
{% if states.sensor.weather_alerts_json.attributes.features %}
{{ states.sensor.weather_alerts_json.attributes.features | length }} active alerts
{% else %}
No active alerts
{% endif %}
attributes:
areas: >
{{ states.sensor.weather_alerts_json.attributes.features | map(attribute='properties.areaDesc') | join(', ') }}
{% else %}
unknown
{% endif %}
events: >
{{ states.sensor.weather_alerts_json.attributes.features | map(attribute='properties.event') | join(', ') }}
{% else %}
unknown
{% endif %}
effective_times: >
{{ states.sensor.weather_alerts_json.attributes.features | map(attribute='properties.effective') | map('as_timestamp') | map('timestamp_custom', '%H:%M %m-%d-%Y') | join(', ') }}
{% else %}
unknown
{% endif %}
expiry_times: >
{{ states.sensor.weather_alerts_json.attributes.features | map(attribute='properties.expires') | map('as_timestamp') | map('timestamp_custom', '%H:%M %m-%d-%Y') | join(', ') }}
{% else %}
unknown
{% endif %}
headlines: >
{{ states.sensor.weather_alerts_json.attributes.features | map(attribute='properties.headline') | join(' | ') }}
{% else %}
unknown
{% endif %}
message_types: >
{{ states.sensor.weather_alerts_json.attributes.features | map(attribute='properties.messageType') | join(', ') }}
{% else %}
unknown
{% endif %}
severities: >
{{ states.sensor.weather_alerts_json.attributes.features | map(attribute='properties.severity') | join(', ') }}
{% else %}
unknown
{% endif %}
certainties: >
{{ states.sensor.weather_alerts_json.attributes.features | map(attribute='properties.certainty') | join(', ') }}
{% else %}
unknown
{% endif %}
urgencies: >
{{ states.sensor.weather_alerts_json.attributes.features | map(attribute='properties.urgency') | join(', ') }}
{% else %}
unknown
{% endif %}
- sensor:
# You can also use https://api.weather.gov/alerts/active/count. I am using multiple zones so it is difficult to count (because two zones can have the same alert), so I am testing this.
- name: "Active Weather Alerts Count"
state: >
{% else %}
0
{% endif %}
This is the automation I built in the UI and use to push to mobile devices.
alias: Active Weather Alerts Push
description: Sends a persistent notification for active weather alerts in Phoenix
- platform: numeric_state
entity_id: sensor.active_weather_alerts_count
above: 0
condition:
- condition: template
value_template: "{{ trigger.from_state.state | int == 0 }}"
- service: notify.mobile_devices
title: Weather Alert
message: >
Events: {{ state_attr('sensor.weather_alert_sensor', 'events') }} \n
Headlines: {{ state_attr('sensor.weather_alert_sensor', 'headlines') }}
\n \n Effective Times: {{
state_attr('sensor.weather_alert_sensor','effective_times') }} \n
Expiry Times: {{ state_attr('sensor.weather_alert_sensor',
'expiry_times') }} \n \n Severities: {{
state_attr('sensor.weather_alert_sensor', 'severities') }} \n
Certainties: {{ state_attr('sensor.weather_alert_sensor', 'certainties')
}} \n Urgencies: {{
state_attr('sensor.weather_alert_sensor','urgencies') }} \n Message
Types: {{ state_attr('sensor.weather_alert_sensor','message_types') }}
\n \n Areas: {{ state_attr('sensor.weather_alert_sensor', 'areas') }} \n
mode: single
