I’m trying to automate a weather announcement. I’ve looked through many topics on this site regarding this, but can’t get it to work.
I have the national weather service installed and running. It is working in the preview editor
However when my google nest executes this same command, it just says “none” and nothing more. What am I doing wrong here?
This is my automation
- id: '1711667890345'
alias: testtttttttt
description: ''
- type: motion
platform: device
device_id: d9ade780d1327377b520f88c82038460
entity_id: 43375b77ce1ac480f67f881e13f5b497
domain: binary_sensor
condition: []
- service: tts.google_say
metadata: {}
entity_id: media_player.nest_mini_office
message: >-
{{state_attr('weather.kalb_daynight', 'forecast')[0]['detailed_description']}}
mode: single
message: >
{% set forecast = state_attr('weather.kalb_daynight', 'forecast')[0] %}
The weather forecast for today is {{ forecast.condition }}, with a temperature of {{ forecast.temperature }} degrees Celsius, and a chance of precipitation of {{ forecast.precipitation_probability }} percent.
![ScreenShot_20240329162544](https://community-assets.home-assistant.io/original/4X/b/8/f/b8fbbb4cdb0ef1f4fd5890287cb9dfdf712d2430.png)
attribution: Data provided by OpenWeatherMap
This doesn’t work for me
Here’s my full automation
alias: testtttttttt
description: ''
- type: motion
platform: device
condition: []
metadata: {}
message: >
{% set forecast = state_attr(weather.kalb_daynight', 'forecast')[0] %}
mode: single
If I check it in the YAML editor, it shows this error
![error](https://community-assets.home-assistant.io/original/4X/5/c/b/5cbc7e4e900de384fcc5f088d689b67dd2ef7d3b.png)
You’re missing a ’ before (weather.kalb_daynight', 'forecast')
on line 16.
Wonderful thanks so much, I got it working
One last thing, would you be able to show me how to get high/low temps for the day? I can’t seem to find which members are in the “forecast” object anywhere so I’m not sure which attribute to point to. For example forecast.temp_min and forecast.temp_max or something along those lines?
I actually don’t think those are exposed/sent on the NWS integration. I use OpenWeatherMap for that. Although, as I type that, my forecast low temp is reading as “Unknown” ![:rofl: :rofl:](https://community.home-assistant.io/images/emoji/twitter/rofl.png?v=12)
![:thinking: :thinking:](https://community.home-assistant.io/images/emoji/twitter/thinking.png?v=12)
forecast.templow
message: >
The weather forecast for today is {{ forecast.condition }}, with a temperature of {{ forecast.temperature }} degrees Celsius, and a chance of precipitation of {{ forecast.precipitation_probability }} percent. The high for today will be {{ forecast.temperature }} degrees Celsius, and the low will be {{ forecast.templow }} degrees Celsius.
