I am trying to set up the OAuth for Google Calendars. I have followed NUMEROUS tutorials and still cannot make it work. I get to the auth screen and enter the code. I log in and then it says “Google hasn’t verified this app”. I click Continue and then I get “Something went wrong”. If I change the OAuth from testing to publisher, I get a screen where I cannot even click continue on the hasn’t verified this app screen.
Likely the client secret is incorrect. Make sure to run the latest version of home assistant and ensure any Application Credentials - Home Assistant have been deleted before you start over.
Did you find a solution? I just clicked on “Advanced” from the pop up error screen. Then click on “Home Assistant (unsafe)” - it is safe! And then “Allow” at the next screen.
When configuring integration, open google . com/device on different device (for example: configuring HA on laptop, open google . com/device on mobile). Type code and accept. Good luck.
The solution for me was to open Home Assistant in a browser without privacy extensions enabled and add the integration there. Enter the app name, client ID, and client secret.
When you see the “Google hasn’t verified this app” error, click on Advanced and then on Go to home-assistant.io (unsafe).
Accept the requested permissions to complete the setup.
Note:
In your Google Cloud project configuration:
Under Authorised redirect URIs, add: https://my.home-assistant.io/redirect/oauth
