Obtain data of a sensor now and one minute ago
Hello.
I obtain the data of a sensor now with this very easy templante:
{{ states('sensor.gas_medicion', now() ) }}
And i want to obtain the value of this sensor, one hour ago. i use this template but not woks :frowning:
{{ states('sensor.gas_medicion', now() - timedelta(hours=1)) }}
this template returns the same value as the first template and i dont know the problem
any idea?
thanks a lot!
The states() function has access to the data in the state object, not the entire database. To access past data you need to set up a SQL sensor. There is an example for previous data that may help you structure the query for your sensor.
FYI, the now() argument you have included in {{ states('sensor.gas_medicion', now() ) }} is not listed as an acceptable arguments for the states() function. I’m kind of surprised you aren’t just getting an error from that template.
I do not think the states() call have a second parameter, so everything after the second ’ is ignored.
In addition to the entity ID, there are some valid secondary arguments for states():
Thanks a lot!!
this information is very usefull, chatgpt in this case dont have the correct information, jeje
I will try with the sql sensor.
Thanks again!!
ChatGPT should be avoided at all cost in relation to HA.
Its even typed into point 23 for the forum guide.
Thanks for that clarification.
It just improved a few cards in my dashboards. :slight_smile:
hello again.
Im trying to use the sql example for this example:
SQL - Home Assistant (home-assistant.io)
And allways apears a error.
with the example of database space, it works fine. this confirm i can obtain data of my mariadb database.
But its imposible to me create a sensor for my gas meter, or a temperature sensor. I try with some sensors and allways the same error ā€œSQL errorā€ :frowning:
I use the sql for the example and only change the sensor name.
any idea? :frowning:
My understanding is that MariaDB requires a different query than the default SQLite database, so you will need to tailor most of what is presented in the HA SQL docs. I am not a SQL expert but based on this thread you likely need to use something like the following:
# column: "state"
SELECT states.state
FROM states
WHERE metadata_id=(SELECT metadata_id
FROM states_meta
WHERE entity_id='sensor.gas_medicion')
  AND last_updated_ts < UNIX_TIMESTAMP(NOW() - INTERVAL 1 HOUR)
ORDER BY last_updated_ts DESC LIMIT 1;
oh i dont think on it.
adapt the query for the mariadb. i thought its the same
very good point! i will try with this and testing,
thanks a lot!
EDIT: THIS QUERY WORKS PERFECT!!!
Thanks a lot
