OCPP integration, Node-Red and Teison EV Charger
I think I really need some assistance, I’m trying to set up a Teison EV charger with OCPP and node red.
For the time being I’ve set up basic Home Assistant automations which turn the unit on when solar power export is above 1.3kw and off when consumption is above 0.4kw.
Next I’ve set up a helper that calculates the desired charge rate setting in Amps from the total power export and the current charge rate (with a minimum rate of 6A as that appears to be the chargers minimum).
{% set e = states('sensor.eagle_200_meter_power_demand') | float %}
{% set c = states('sensor.farm_charger_current_import') | float %}
{% if (((e * -1000)/240) + (c -1) )|round(0) > 6 | float %}
{{ (((e * -1000)/240) + (c -1) )|round(0)}}
 {% else %}
            {{6}}
          {% endif %}
Finally i’ve attempted to set up a node-red flow that adjusts the charge rate.
        "id": "281a947a8b14ff9e",
        "type": "tab",
        "label": "Teison Charger",
        "disabled": false,
        "info": "",
        "env": []
        "id": "b04e52fda3e61e34",
        "type": "inject",
        "z": "281a947a8b14ff9e",
        "name": "Every 3 minutes",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "180",
        "crontab": "",
        "once": true,
        "onceDelay": "10",
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 130,
        "y": 60,
        "wires": [
                "be9d746797bb56f6"
        "id": "be9d746797bb56f6",
        "type": "api-current-state",
        "name": "Nic at home",
        "server": "eab52739.9cf7d8",
        "version": 3,
        "outputs": 2,
        "halt_if": "home",
        "halt_if_type": "str",
        "halt_if_compare": "is",
        "entity_id": "person.nic",
        "state_type": "str",
        "blockInputOverrides": true,
        "outputProperties": [
                "property": "payload",
                "propertyType": "msg",
                "value": "",
                "valueType": "entityState"
                "property": "data",
                "value": "",
                "valueType": "entity"
        "for": "0",
        "forType": "num",
        "forUnits": "minutes",
        "override_topic": false,
        "state_location": "payload",
        "override_payload": "msg",
        "entity_location": "data",
        "override_data": "msg",
        "x": 330,
        "y": 60,
        "wires": [
                "546711f7015f21f3"
                "0adfd55bbd68c670"
        "id": "0adfd55bbd68c670",
        "name": "Moose at home",
        "version": 3,
        "outputs": 2,
        "halt_if": "home",
        "entity_id": "person.lucy",
                "value": "",
                "property": "data",
                "value": "",
        "for": "1",
        "forType": "num",
        "x": 540,
        "y": 60,
        "wires": [
                "546711f7015f21f3"
        "id": "2241e15b5a26e675",
        "name": "Get EV Charge Rate",
        "server": "41108723.0bf848",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "sensor.ev_charge_rate",
                "value": "",
                "valueType": "num"
                "property": "data",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 160,
        "y": 240,
        "wires": [
                "bdb53f1b2c30e860"
        "id": "bdb53f1b2c30e860",
        "type": "api-call-service",
        "name": "Set Teison",
        "version": 7,
        "debugenabled": true,
        "action": "ocpp.set_charge_rate",
        "floorId": [],
        "areaId": [],
        "deviceId": [],
        "entityId": [],
        "labelId": [],
        "data": "{\"devid\":\"car_charger\",\"limit_amps\":\"payload\"}",
        "dataType": "jsonata",
        "mergeContext": "",
        "mustacheAltTags": false,
                "value": "",
                "valueType": "str"
        "queue": "none",
        "blockInputOverrides": false,
        "domain": "ocpp",
        "service": "set_charge_rate",
        "x": 410,
        "y": 240,
        "wires": [
        "id": "546711f7015f21f3",
        "name": "Charger is on",
        "version": 3,
        "outputs": 2,
        "halt_if": "on",
        "entity_id": "switch.farm_charger_charge_control",
                "value": "",
                "property": "data",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 140,
        "y": 160,
        "wires": [
                "2241e15b5a26e675"
        "id": "eab52739.9cf7d8",
        "type": "server",
        "name": "Home Assistant",
        "addon": true,
        "rejectUnauthorizedCerts": true,
        "ha_boolean": "",
        "connectionDelay": false,
        "cacheJson": false,
        "heartbeat": false,
        "heartbeatInterval": "",
        "statusSeparator": "",
        "enableGlobalContextStore": false
        "id": "41108723.0bf848",
        "type": "server",
        "version": 5,
        "addon": true,
        "ha_boolean": "y|yes|true|on|home|open",
        "connectionDelay": true,
        "cacheJson": true,
        "heartbeat": false,
        "heartbeatInterval": 30,
        "areaSelector": "friendlyName",
        "deviceSelector": "id",
        "entitySelector": "id",
        "statusSeparator": "at: ",
        "statusYear": "hidden",
        "statusMonth": "short",
        "statusDay": "numeric",
        "statusHourCycle": "h23",
        "statusTimeFormat": "h:m",
        "enableGlobalContextStore": true
I’m stuck at
1/ the spamming of notifications from the charger
• randomly “Warning: Start transaction failed with response Rejected”
• and regularly “Charger 0312209102324480672 rebooted”
• and “Warning: charger reported Rejected while setting MeterValuesSampledData=Current.Export,Current.Import,Current.Offered,Energy.Active.Export.Interval,Energy.Active.Export.Register,Energy.Active.Import.Interval,Energy.Active.Import.Register,Energy.Reactive.Export.Interval,Energy.Reactive.Export.Register,Energy.Reactive.Import.Interval,Energy.Reactive.Import.Register,Frequency,Power.Active.Export,Power.Active.Import,Power.Factor,Power.Offered,Power.Reactive.Export,Power.Reactive.Import,RPM,SoC,Temperature,Voltage”
2/ My Edit action node in node-red is wrong. I can’t work out how to send the sensor.ev_charge_rate to the charger.
if anyone can assist me I’d be eternally grateful
Nic
I’m still fighting with this a days later.
Removing the OCPP integration and setting it up again hasn’t helped the notification spamming.
HA restart gives me one reboot notification and two “Warning: charger reported Rejected while setting …(and a list of items)”
I can however set the charge rate by adding {“devid”:“55a20831ab993f34d0b2bcde6b5ba5e7”, “limit_amps”:6 }
into the data field in the Edit action node.
I’ve no luck in getting that numerical value to auto set from either an Edit current state node, or by replacing it with any verion of
"{{ states(‘sensor.ev_charge_rate'with_unit=False) }}"
that I can think of.
Googling draws a blank so I’m starting to think this isn’t possible :frowning:
Hey Nic,
Taking a look at what you posted, those nodes you are using is for the NR dashboard and not HA’s. To create entities in HA, install the nodered companion and use the HA entity nodes.
Thanks Mikefila, I’ll have a look at that.
That may make my like easier!
Nic
Ok while those extra nodes are certainly useful (and I’ve added a switch in Home assistant to turn the flow off), I don’t think that’s where my problem is.
I’m using these nodes?
I’m at a loss now as to whether the problem is my charger, the occp integration or the last node in my node red flow.
OCPP integration is spewing errors as well as the ones listed in my first post ie.
The unit of ‘Farm Charger Power Reactive Export’ (sensor.farm_charger_power_reactive_export) changed to ‘kWh’ which can’t be converted to the previously stored unit, ‘var’.
If the historic statistic values have a wrong unit, you can update the units of the old values. The values will not be updated.
I’ve deleted everything and reset it all up.
entries are there in the integration but availability is always off. An I can’t even be sure that the maximum current slider works. The changes aren’t reflected in the Teison app.
In desperation I’ve sent off an email to teison in China to see if they have any insight.
My current node red flow in case anyone has any ideas:
        "type": "tab",
        "disabled": false,
        "info": "",
        "env": []
        "type": "inject",
        "name": "Every5 minutes",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "300",
        "crontab": "",
        "once": true,
        "onceDelay": "7",
        "topic": "",
        "payload": "",
        "x": 140,
        "y": 40,
        "wires": [
                "406080253406621f"
        "version": 3,
        "outputs": 2,
        "halt_if": "home",
                "value": "",
                "property": "data",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 190,
        "y": 340,
        "wires": [
                "1423975b62f3ec1d"
                "0adfd55bbd68c670"
        "version": 3,
        "outputs": 2,
        "halt_if": "home",
                "value": "",
                "property": "data",
                "value": "",
        "for": "1",
        "forType": "num",
        "x": 200,
        "y": 400,
        "wires": [
                "1423975b62f3ec1d"
        "version": 3,
        "outputs": 1,
        "halt_if": "",
                "value": "",
                "valueType": "num"
                "property": "data",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 720,
        "y": 340,
        "wires": [
                "7f5b755775e57eb5"
        "version": 3,
        "outputs": 2,
        "halt_if": "on",
                "value": "",
                "property": "data",
                "value": "",
        "for": "10",
        "forType": "num",
        "x": 700,
        "y": 100,
        "wires": [
                "023c2c1ddbf330e0"
        "id": "97341dd6b4761506",
        "type": "server-state-changed",
        "name": "Charger turns on",
        "version": 6,
        "outputs": 2,
        "exposeAsEntityConfig": "",
        "entities": {
            "entity": [
            "substring": [],
            "regex": []
        "outputInitially": false,
        "stateType": "str",
        "ifState": "on",
        "ifStateType": "str",
        "ifStateOperator": "is",
        "outputOnlyOnStateChange": true,
        "for": "0",
        "forType": "num",
        "ignorePrevStateNull": false,
        "ignorePrevStateUnknown": false,
        "ignorePrevStateUnavailable": false,
        "ignoreCurrentStateUnknown": false,
        "ignoreCurrentStateUnavailable": false,
                "value": "",
                "property": "data",
                "value": "",
                "valueType": "eventData"
                "property": "topic",
                "value": "",
                "valueType": "triggerId"
        "x": 120,
        "y": 460,
        "wires": [
                "2241e15b5a26e675"
        "id": "2bed658ce98f76de",
        "name": "Power to grid >1.3kw",
        "version": 3,
        "outputs": 2,
        "halt_if": "-1.3",
        "halt_if_type": "num",
        "halt_if_compare": "lt",
        "entity_id": "sensor.eagle_200_meter_power_demand",
                "value": "",
                "property": "data",
                "value": "",
        "for": "5",
        "forType": "num",
        "x": 220,
        "y": 260,
        "wires": [
                "be9d746797bb56f6"
        "id": "fecd5dd9420b0abd",
        "name": "Power from grid >400w",
        "version": 3,
        "outputs": 2,
        "halt_if": "0.4",
        "halt_if_compare": "gt",
                "value": "",
                "property": "data",
                "value": "",
        "for": "5",
        "forType": "num",
        "x": 450,
        "y": 100,
        "wires": [
                "546711f7015f21f3"
                "1f77c33eaa965a41"
        "id": "023c2c1ddbf330e0",
        "type": "ha-device",
        "name": "Turn off charger",
        "version": 1,
        "inputs": 1,
        "deviceType": "action",
        "device": "55a20831ab993f34d0b2bcde6b5ba5e7",
        "event": {
            "type": "turn_off",
            "device_id": "55a20831ab993f34d0b2bcde6b5ba5e7",
            "entity_id": "fa49c73ef9966ebf3ef60565ff509f84",
            "domain": "switch",
            "metadata": {
                "secondary": false
        "capabilities": [],
        "outputProperties": [],
        "x": 760,
        "y": 180,
        "wires": [
        "id": "1423975b62f3ec1d",
        "name": "Turn on charger",
        "version": 1,
        "inputs": 1,
        "event": {
            "type": "turn_on",
            "domain": "switch",
            "metadata": {
                "secondary": false
        "capabilities": [],
        "x": 420,
        "y": 340,
        "wires": [
                "2241e15b5a26e675"
        "id": "1f77c33eaa965a41",
        "version": 3,
        "outputs": 2,
        "halt_if": "on",
                "value": "",
                "property": "data",
                "value": "",
        "for": "",
        "forType": "num",
        "x": 200,
        "y": 180,
        "wires": [
                "bc46c325fcf72e1d"
                "2bed658ce98f76de"
        "id": "406080253406621f",
        "type": "ha-switch",
        "name": "Car Charge Automation",
        "version": 0,
        "debugenabled": false,
        "inputs": 1,
        "outputs": 2,
        "entityConfig": "c91796e35b7292cb",
        "enableInput": true,
        "outputOnStateChange": true,
                "property": "outputType",
                "value": "state change",
                "valueType": "str"
                "value": "",
        "x": 220,
        "y": 100,
        "wires": [
                "fecd5dd9420b0abd"
        "id": "7f5b755775e57eb5",
        "version": 7,
        "floorId": [],
        "areaId": [],
        "deviceId": [],
        "entityId": [],
        "labelId": [],
        "data": "{\t   \"devid\":\"55a20831ab993f34d0b2bcde6b5ba5e7\",\t   \"limit_amps\":sensor.ev_charge_rate,\t   \"conn_id\":0,\t   \"custom_profile\":\"{\\\"chargingProfileId\\\":8,\\\"stackLevel\\\":0,\\\"chargingProfileKind\\\":\\\"Relative\\\",\t   \\\"chargingProfilePurpose\\\":\\\"ChargePointMaxProfile\\\",\\\"chargingSchedule\\\":{\\\"chargingRateUnit\\\":\\\"A\\\",\t   \\\"chargingSchedulePeriod\\\":[{\\\"startPeriod\\\":0,\\\"limit\\\":16}]}}\"\t}",
        "mergeContext": "",
                "value": "data",
                "valueType": "msg"
        "queue": "none",
        "domain": "ocpp",
        "x": 770,
        "y": 460,
        "wires": [
        "id": "bc46c325fcf72e1d",
        "name": "Is Car Charging?",
        "version": 3,
        "outputs": 2,
        "halt_if": "1",
        "entity_id": "sensor.farm_charger_current_import",
                "value": "",
                "property": "data",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 470,
        "y": 180,
        "wires": [
                "2241e15b5a26e675"
        "type": "server",
        "addon": true,
        "ha_boolean": "",
        "cacheJson": false,
        "heartbeat": false,
        "id": "c91796e35b7292cb",
        "type": "ha-entity-config",
        "deviceConfig": "",
        "name": "car_charge_automation",
        "version": 6,
        "entityType": "switch",
        "haConfig": [
                "property": "name",
                "value": "Car Charge Automation"
                "property": "icon",
                "value": "mdi:car"
                "property": "entity_picture",
                "value": ""
                "property": "entity_category",
                "value": "config"
                "property": "device_class",
                "value": "switch"
        "resend": false,
        "debugEnabled": false
I’m still fighting with this charger and I’m at a loss now as to what to do next.
Is anyone able to give me a hint as to whether these settings look right?
the charger still does not respond to the changes
I looked through the ocpp docs and cannot find an example of the action. The section labeled data needs to be filled out. Do you have a yaml example of how to use this action?
Edit: If you can’t find an example go to dev tools → actions. Choose the ocpp action. Take a screenshot of the fields the editor shows.
Thanks Mike, that may be the extra info I needed.
Here is the screenshot of the dev tools → actions (i didn’t know about that)
I’ve added {"devid":"55a20831ab993f34d0b2bcde6b5ba5e7", "limit_amps”:payload } to the data section
debug shows this:
`18/04/2025, 1:31:04 pmSet Teisonmsg :
object
domain: “ocpp”
service: “set_charge_rate”
target: object
data: object
devid: “55a20831ab993f34d0b2bcde6b5ba5e7”
limit_amps: “9”
18/04/2025, 1:31:05 pmnode: debug 1
msg.payload : string[1]
“9”
`I think it’s working!
I’ll monitor it for the next few days and see how it goes.
-Nic
A final update to this in case anyone else wants to set up a node-red EV charge controller. I’m new to this and had a lot of trouble getting the information.
I had some problems where the OCPP integration was messing up after sending a charge rate 0 (pausing charging rather than switching it off).
The unit could not recover and would not report values.
The OCPP dev suggested:
Your charger supports more metervalues that it can handle.
Disable automatic discovery of metavalues and just select the metavalues you need.
Probably 4-5 should be enough :slight_smile:
I removed the OCPP integration and re added it with only a couple if meta values
That fixed that issue.
Hy helper template looks like this:
{% if (((e * -1000)/240) + (c -0) )|round(0) > 5 | float %}
  {{ (((e * -1000)/240) + (c -0) )|round(0)}}
{% else %}
  {{0}}
{% endif %}
I’m sure it’s unnecessarily complex, but I’m a beginner at this.
I’ve left in the (c -0) . It was set at -1 to leave a little headroom in the power to grid but it’s winter now and I need all the charge I can get for the car.
I may change it back to -1 in summer.
Here is the working node-red flow:
        "type": "tab",
        "disabled": false,
        "info": "",
        "env": []
        "type": "inject",
        "name": "Every 10 minutes",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "600",
        "crontab": "",
        "once": true,
        "onceDelay": "7",
        "topic": "",
        "payload": "",
        "x": 150,
        "y": 100,
        "wires": [
                "406080253406621f"
        "name": "[Person1] at home",
        "version": 3,
        "outputs": 2,
        "halt_if": "home",
        "entity_id": "person.[Person1]",
                "value": "",
                "property": "data",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 190,
        "y": 420,
        "wires": [
                "1423975b62f3ec1d"
                "0adfd55bbd68c670"
        "name": "[Person2] at home",
        "version": 3,
        "outputs": 2,
        "halt_if": "home",
        "entity_id": "person.[Person2]",
                "value": "",
                "property": "data",
                "value": "",
        "for": "1",
        "forType": "num",
        "x": 200,
        "y": 480,
        "wires": [
                "1423975b62f3ec1d"
        "version": 3,
        "outputs": 1,
        "halt_if": "",
                "value": "",
                "property": "data",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 720,
        "y": 420,
        "wires": [
                "7f5b755775e57eb5"
        "version": 3,
        "outputs": 2,
        "halt_if": "on",
                "value": "",
                "property": "data",
                "value": "",
        "for": "10",
        "forType": "num",
        "x": 740,
        "y": 260,
        "wires": [
                "023c2c1ddbf330e0"
        "version": 6,
        "outputs": 2,
        "entities": {
            "entity": [
            "substring": [],
            "regex": []
        "stateType": "str",
        "ifState": "on",
        "for": "0",
        "forType": "num",
                "value": "",
                "property": "data",
                "value": "",
                "value": "",
        "x": 120,
        "y": 540,
        "wires": [
                "2241e15b5a26e675"
        "version": 3,
        "outputs": 2,
        "halt_if": "-1.3",
                "value": "",
                "property": "data",
                "value": "",
        "for": "5",
        "forType": "num",
        "x": 220,
        "y": 340,
        "wires": [
                "be9d746797bb56f6"
        "version": 3,
        "outputs": 2,
        "halt_if": "0.4",
                "value": "",
                "property": "data",
                "value": "",
        "for": "5",
        "forType": "num",
        "x": 510,
        "y": 180,
        "wires": [
                "9ed59e0b91e3c67e"
        "version": 1,
        "inputs": 1,
        "event": {
            "type": "turn_off",
            "entity_id": "1a1d70ebb349a3b893dbd434306295de",
            "domain": "switch",
            "metadata": {
                "secondary": false
        "capabilities": [],
        "x": 900,
        "y": 340,
        "wires": [
        "version": 1,
        "inputs": 1,
        "event": {
            "type": "turn_on",
            "domain": "switch",
            "metadata": {
                "secondary": false
        "capabilities": [],
        "x": 440,
        "y": 420,
        "wires": [
                "2241e15b5a26e675"
        "version": 3,
        "outputs": 2,
        "halt_if": "on",
                "value": "",
                "property": "data",
                "value": "",
        "for": "",
        "forType": "num",
        "x": 200,
        "y": 260,
        "wires": [
                "2241e15b5a26e675"
                "2bed658ce98f76de"
        "version": 0,
        "inputs": 1,
        "outputs": 2,
                "valueType": "str"
                "value": "",
        "x": 220,
        "y": 180,
        "wires": [
                "fecd5dd9420b0abd",
                "1f77c33eaa965a41"
        "version": 7,
        "floorId": [],
        "areaId": [],
        "deviceId": [],
        "entityId": [],
        "labelId": [],
        "data": "{\"devid\":\"55a20831ab993f34d0b2bcde6b5ba5e7\", \"limit_amps\":payload}",
        "mergeContext": "",
        "queue": "none",
        "domain": "ocpp",
        "x": 890,
        "y": 540,
        "wires": [
        "id": "9ed59e0b91e3c67e",
        "type": "time-range-switch",
        "name": "",
        "lat": "",
        "lon": "",
        "startTime": "18:00",
        "endTime": "23:00",
        "startOffset": 0,
        "endOffset": 0,
        "x": 750,
        "y": 180,
        "wires": [
                "546711f7015f21f3"
        "id": "095847d601137060",
        "name": "[Person1] arrives home",
        "version": 6,
        "outputs": 2,
        "entities": {
            "entity": [
                "person.[Person1]"
            "substring": [],
            "regex": []
        "stateType": "str",
        "ifState": "home",
        "outputOnlyOnStateChange": false,
        "for": "10",
        "forType": "num",
                "value": "",
                "property": "data",
                "value": "",
                "value": "",
        "x": 400,
        "y": 100,
        "wires": [
                "406080253406621f"
        "type": "server",
        "addon": true,
        "ha_boolean": "",
        "cacheJson": false,
        "heartbeat": false,
        "deviceConfig": "",
        "version": 6,
        "haConfig": [
                "property": "name",
                "property": "icon",
                "value": "mdi:car"
                "value": ""
                "value": "config"
                "value": "switch"
        "resend": false,
