I had been used to do regular updates without facing any difficulties but October release was preventing Home Assistant to restart smoothly (had to revert to 2024.09.03).
Similarly, 2024.11.1 Release does not allow a full operational use of the system. Had to revert to 2024.09.3 again (issue with ‘go2rtc’ integration), sonos integration, spotify (spotifyaio’ does not exist).
Thank you
Hope a bug correction release will improve this situation
Did you open issues on github, if there aren’t already ones open for your problems (search first)?
If not then your issues are unlikely to be fixed.
Thanks for your message. I did not submit anything because the submission process requests that I have taken down the logs (I did not as my first priority is to return the system to full operation). I wait because I believe that I will not be the only one facing the same issue (I did not modify my configuration since long, beside the Home Assistant regular updates).
Thanks anyway
Note: I did some search on github and both issues are effectively reported. I am confident that a new release will come soon.
