Hello guys
i have y octoprint setup through Home assistant plug in.
i have main power source for my 3d printer and octoprint through sonoff mini flashed with Esphome
im trying to shutdown the printer and octoprint after the print finish and the nozzel temp reach below 50C. here is my automation
As far as I understand, this will only trigger once when Octoprint changes state.
Consider that the temperature when the printer finishes is 190 degrees; will this automation complete? No.
190 degrees is higher than 50 degrees.
You need a way to keep checking until the printer temperature reaches 50.
Not certain, but that is my interpretation of why it’s not working for you.
You are correct thats the problem i have been trying to solve it but no luck ,should keep the trigger on for specific time ? or maybe another way to keep checking on condition?
Planing on doing that when i finish the automation but for people sack i already mentioned the solution which was wait for template not trigger
Thanks for sharing yours.
