mwieting
(matthew Wieting)
June 4, 2019, 2:24pm
1
I am trying to integrate octoprint into my home assistant.
octoprint:
host: 172.xxx.xxx.xxx
api_key: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
port: 5000
bed: true
sensors:
monitored_conditions:
- ‘Current State’
- ‘Job Percentage’
- ‘Temperatures’
My first question is how do i get the temp sensor for the hot end. Secondly, how do i get the temp to show in C instead of F
You need to include: “number_of_tools: 1” place that under “bed: true” and to keep the C instead of the F, you need to place this in your customize.yaml:
sensor.your_printer_actual_tool0_temp:
unit_of_measurement: 'ºC'
sensor.your_printer_target_tool0_temp:
sensor.your_printer_actual_bed_temp:
sensor.your_printer_target_bed_temp:
I think that will do it for you.
mwieting
(matthew Wieting)
June 5, 2019, 11:52am
3
like this?
octoprint:
port: 5000
bed: true
number of tools: 2
sensors:
- ‘Current State’
- ‘Job Percentage’
- ‘Temperatures’
- sensor.your_printer_actual_tool0_temp:
unit_of_measurement: ‘ºC’
- sensor.your_printer_target_tool0_temp:
- sensor.your_printer_actual_bed_temp:
- sensor.your_printer_target_bed_temp:
No, the customize items will go under the customize section in you configuration.yaml or in the customize.yaml if you split your config. Check this out:
mwieting
(matthew Wieting)
June 10, 2019, 9:00am
5
TinyDoT:
number_of_tools: 1
Okay. I’ll give that a try. Thanks
