Octoprint: upload failed > Maximum request body size
I am not able to able a gcode file via the Octoprint Web UI to my printer.
What’s wrong here?
Message
Upload fail: Maximum request body size 16777216 exceeded, actual body size 16998885
This is probably more of a OctoPrint issue, so you should take it there.
The message indicate that the gcode file might be too big, though.
It’s seems it’s a Home Assistant topic, but I don’t see a solution?
https://github.com/home-assistant/supervisor/issues/2950
I do not see an option to upload gcode from my HA Octoprint integration, so are you running octoprint on the same hardware (or VM) as HA?
not from the integration, 3D Printer add on
Well, it seemed there was made a solution and that was to use streams, instead of increase the post limit.
The higher post limits seems to be using too many resources, which would affect the entire system, so streaming was chosen instead, but streaming requires that the services have to written to use streaming for large data volumes.
