Octopus Agile Automation based on price bracket to charge batteries from PV system
I started some basic automation via HA to charge my battery 10kwH if electricity is cheap on Octotpus Agile import
I use a scheduled trigger with the 30-minute rates that I create every day to switch between self-consumption and Time of Use for that period.
This is boring to look at the next time with cheap tariffs to charge the battery.
So I want to do is to set a price bracket where I want to charge let say below 0.1898 kWh and above 0.1899 kWh to not charge the battery.
So far so good the challenge I have is I want to let HA check every 30 minutes for the next tariff as above.
Hope that makes sense.
so far I have the below how can I integrate the 30-minute check for the new tariff or what else could I use to determine the next time I want to charge?
choose:
  - conditions:
      - condition: state
        entity_id: select.battery_working_mode
        state: Maximise Self Consumption
      - condition: numeric_state
        entity_id: >-
          sensor.octopus_energy_electricity_XXXXXX_current_rate
        below: 0.1898
    sequence:
      - device_id: XXXXXXXXXXXXXXXXXXXXXXXX
        domain: select
        type: select_option
        option: Time Of Use
  - conditions:
      - condition: state
        state: Time Of Use
        entity_id: >-
          sensor.octopus_energy_electricity_XXXXXXXXX_current_rate
        above: 0.1899
    sequence:
        domain: select
        type: select_option
        option: Maximise Self Consumption
Thanks for sharing this. Which Octupus Agile tariff integration do you use?
You could try via a trigger
  • platform: state
    entity_id:
    • schedule.hlp_switch_battery_mode
    • select.battery_working_mode
      enabled: false
  • platform: time_pattern
    hours: “0”
    minutes: “30”
    seconds: “00”
    enabled: true
I am looking to do something similar,
What integration are you using to get the rates please.
I have control over the inverter and can set the charge time using the Solax Modbus integration and a Waveshare Industrial Serial Server RS485 To RJ45 Ethernet. Soldered it into the WiFi adaptor and set the Waveshare to be multi-host to avoid conflict.
I am missing the Octopus Agile rates to switch the charge on and off.
I also saw a warning regarding writing to the inverter too often.
Solis Rai-3K inverter with Pylontech batteries.
Octopus Agile tariff.
Sorry for the late response I use octopus integration BottlecapDave (David Kendall) · GitHub
and HACS Huawei solar wlcrs (Thijs W.) · GitHub
Hi - I set about this as well, but have found success using this - GitHub - fboundy/pv_opt: Home Assistant PV Optimisation for Solis Inverters
Automates the whole process.
Good luck !
I’m new to Home Assistant and working on a similar process to automate charging of a plug in hybrid vehicle. I’ve added a Shelly relay to my dumb charger which then allows me to remotely control the vehicle charging. I’m on Octopus Agile and use the Octopus integration from BottlecapDave to read back the rates
I’ve made a simple integration of an input box where I can enter the target rate to charge the vehicle by adding the following code in the Configuration.yaml file
input_number:
  box1:
    name: Limit for charging
    initial: 0.12
    min: 0
    max: 1
    step: 0.001
    mode: box
I’ve then created a couple of simple automation routines to toggle the Shelly relay if the current rate is above or below the value entered in the input box.
Here is the code in the Automations yaml editor which switches the charger via the Shelly relay.
alias: Turn on below charge limit
description: |-
  If cost is below charge limit p/kWh
  turn on socket
  - platform: state
    entity_id:
      - sensor.octopus_energy_electricity_**(MY ACCOUNT)**_current_rate
condition:
    entity_id: input_number.box1
    above: sensor.octopus_energy_electricity_**(MY ACCOUNT)**_current_rate
  - type: turn_on
    device_id: **(SHELLY RELAY)**
    entity_id: **(SHELLY RELAY SWITCH)**
    domain: switch
mode: single
alias: Turn off above charge limit
description: |-
  If cost is above charge limit p/kWh
  turn off socket
  - platform: state
    entity_id:
condition:
    below: sensor.octopus_energy_electricity_**(MY ACCOUNT)**_current_rate
  - type: turn_off
    domain: switch
mode: single
I’m sure there is a more elegant way of doing this and open to suggestions on my code but it seems to work well so far.
Now I need to find a way to automatically determine the optimum value put in the input box based on today’s/tomorrow’s rate to get the cheapest possible charging.
