Is there a way to see the current meter reading via the Octopus Energy integration and my Octopus Home Mini? I thought this would be the entity current_accumulative_consumption but it seems this will only give me statistics for hour, day, week etc and not the reading I get (eventually) by fiddling with the buttons on both meters - that is, the total consumption since each meter was installed.
I need this because for years I’ve been tracking our monthly gas and electricity usage in an Excel spreadsheet, which requires a monthly reading.
The ‘smart’ meter holds registers with the accumulated total energy since first used. As you know, you can read these directly from the meter.
With a compatible In Home Display (IHD) using the Home Area Network (HAN) the display can interrogate the meter to give you these figures. The Octopus Home Mini is an adjunct to an IHD, in that it connects to the meter via the HAN, reads the live consumption, and pushes this to Octopus HQ via the Internet. From there you can get at these figures using the Octopus App.
BottlecapDave’s great integration uses the Octopus API calls to get at the account and the associated meter details, and can provide the previous day consumption readings and a lot more, including pulling back from Octopus the current Home Mini live consumption figures. What it can’t appear to do is get the meter register (total) figures.
I too track my energy use by Excel spreadsheet, and I use my IHD on my desk, and wait for my Octopus energy bill which has my import figures (the ‘smart’ IHD can’t manage those…).
One possible solution would be to set a base meter reading for the start of the year (update once a year) then use Octopus API to pull in all consumption since the start of the year, and add the lot up. This would, on a rolling basis, give a ‘register total’ figure.
Thanks Geoff. I managed to miss your response at the time but had already concluded that I would have to keep reading the meters manually each month for my spreadsheet.
I’ve managed to setup meter readings using Octopus energy.
I’ve setup a helper for both my Gas and Electricity using the Octopus Energy HACS integration which provides a _current_totale_consumption value.
Just to make sure it matches what my meters and IHD show, I’ve added a changeable number delta to add/subtract from that.
It seems to work well so far!
The template helper for the meter reading looks like:
Hi @DerekO I am an HA newbie but desperate to get a meter reading from my Octopus meters. I have installed the Octopus Energy HA integration but I have never set up a helper before. Can you give me any tips/guidance please? TIA
Templates are just a way of creating a sensor, switch, etc. based on other entities. In this case, I’ve created a Template Sensor based on readings from the Octopus HACS integration.
To create one, go into Settings, Devices & Services, and then Helpers. Click on Create Helper and, for this use, choose Template and then Template a sensor.
It will ask you for the sensor name (pick your own), unit of measurement (I used “kW”), device class (“Power”, state class (left blank) and device (I used Electricity Meter), as well as the template.
For the template, I used the following, but this will need amending to use the sensors from your Octopus integraiton:
I also created another helper that is used in this template - input_number.electricity_meter_offset. Same approach, but create a Number helper this time. I use this to adjust the meter reading to get an exact match to what is shown on my HUD. Once you configure it the first time you can just leave it alone.
