Hi there,
I’ve recently had a Octopus smart energy meter installed, with a small screen display (potentially an Octopus Home Mini). The chap installing it has said that it supports zigbee and I should be able to connect to it locally, rather than having to get data via an external Octopus API for instance.
However, when I search on here and elswhere, I’m not sure if that’s actually the case?! Has anyone used Home Assistant installed on a raspberry pi (with a zigbee dongle of course), to connect to an Octopus smart meter and been able to retrieve data from the meter rather than via an API??
If so, is there a tutorial on how this might be done?
Any help would be very much appreciated!
Cheers, Matt K
