I have problems with my Home Assistant setup and can’t track down where the problem is. Firstly I should mention that my Octopus Energy integration worked along with everything else for the first year or two of installation but has now stopped. I got energy readings until 28 October but not after that, and I can’t attribute this to an upgrade without knowing where these would be logged. An add-on called log viewer used to show the most recent errors in HA with date and time but now just shows the following.
return self._sock.recv_into(b)
File "/usr/local/lib/python3.13/ssl.py", line 1304, in recv_into
return self.read(nbytes, buffer)
File "/usr/local/lib/python3.13/ssl.py", line 1138, in read
return self._sslobj.read(len, buffer)
I’m puzzled that the directory listing below doesn’t show a file called home-assistant.log and that there seems to be no current log (that is, last updated Nov 21), even in the .fault file.
I’m running the following on an Intel X86 NUC:
Installation method Home Assistant OS
Core 2025.11.2
Supervisor 2025.11.4
Operating System 16.3
Frontend 20251105.0
Any ideas?
Welcome to the Home Assistant command line interface.
Home Assistant Supervisor is running!
System information:
IPv4 addresses for wlp1s0: (No address)
IPv4 addresses for enp2s0: 192.168.1.37/24
IPv6 addresses for enp2s0: fe80::499:ac54:3b7:f45e/64OS Version: Home Assistant OS 16.3
Home Assistant Core: 2025.11.2Home Assistant URL: http://homeassistant.local:8123
Observer URL: http://homeassistant.local:4357System is ready! Use browser or app to configure.
➜ ~ cd /config
➜ /config ls -l home*
-rw-r–r-- 1 root root 19759 Nov 4 20:43 home-assistant.log.1
-rw-r–r-- 1 root root 0 Nov 20 19:57 home-assistant.log.fault
-rw-r–r-- 1 root root 20448 Nov 6 07:00 home-assistant.log.old
-rw-r–r-- 1 root root 54165504 Nov 21 13:20 home-assistant_v2.db
-rw-r–r-- 1 root root 131072 Nov 21 13:22 home-assistant_v2.db-shm
-rw-r–r-- 1 root root 4268352 Nov 21 13:22 home-assistant_v2.db-wal Text
