Here is the yaml for the dashboard
kiosk_mode:
hide_header: true
hide_sidebar: true
theme: ios-dark-mode-dark-blue
- type: panel
title: Calendar Display
path: calendar-display
badges: []
cards:
- type: vertical-stack
cards:
- type: horizontal-stack
cards:
- type: conditional
conditions:
- entity: input_select.display_1080ph_element
state: Ian Calendar
card:
cards:
- initial_view: listWeek
type: calendar
entities:
- calendar.o365_ian
- type: conditional
conditions:
state: General Information
card:
cards:
cards:
cards:
- type: custom:clock-weather-card
entity: weather.pirateweather_week
sun_entity: sun.sun
forecast_days: 6
- type: custom:hourly-weather
entity: weather.pirateweather_hourly
icons: true
show_wind: 'false'
show_precipitation_probability: false
cards:
- type: custom:mushroom-title-card
title: General Information
alignment: center
- type: custom:todoist-card
entity: sensor.to_do_list
show_header: true
show_completed: 1
show_item_add: true
show_item_close: true
show_item_delete: false
only_today_overdue: false
- type: conditional
conditions:
state: Lights
card:
cards:
title: Lights
cards:
cards:
title: Outdoor
- type: custom:mushroom-light-card
entity: light.outdoor_lights
layout: vertical
- square: false
columns: 2
type: grid
cards:
entity: light.front_lights
entity: light.back_lights
cards:
title: 1st Floor
entity: light.first_floor_lights
layout: vertical
- square: false
columns: 2
type: grid
cards:
entity: light.garage_entry_lights
entity: light.kitchen_lights
entity: light.dining_room_lights
entity: light.living_room_lights
entity: light.foyer_lights
entity: light.front_entry_lights
cards:
title: 2nd Floor
entity: light.second_floor_lights
layout: vertical
- square: false
columns: 2
type: grid
cards:
entity: light.stair_lights
entity: light.hall_lights
entity: light.master_bedroom_lights
entity: light.guest_room_lights
entity: light.office_lights
show_color_temp_control: true
show_color_control: true
show_brightness_control: true
collapsible_controls: true
entity: light.library_lights
- type: conditional
conditions:
state: House State
card:
cards:
cards:
cards:
title: House Sate
- type: custom:mushroom-alarm-control-panel-card
entity: alarm_control_panel.alexa_guard_7808f
states:
- armed_home
- armed_away
cards:
primary: Thermostat
secondary: >
{%if is_state('binary_sensor.cool', 'on')%}
Cooling Mode
{%elif is_state('binary_sensor.heat',
'on')%} Heating Mode
{%else%} ERROR
{%endif%}
icon: >
mdi:snowflake
'on')%} mdi:weather-sunny
{%else%} mdi:alert-circle-outline
{%endif%}
tap_action:
action: none
hold_action:
action: more-info
double_tap_action:
action: none
icon_color: >
blue
'on')%} red
{%else%} white
{%endif%}
layout: horizontal
entity: ''
primary: Power Cost
secondary: >-
{%if is_state('input_select.power_cost',
'On-peak')%} On-peak
{%elif is_state('input_select.power_cost',
'Off-peak')%} Off-peak
'Super Off-peak')%} Super Off-peak
{%else%} ERROR
{%endif%}
icon: mdi:lightning-bolt-circle
tap_action:
action: none
hold_action:
action: more-info
double_tap_action:
action: none
icon_color: >-
'On-peak')%} red
'Off-peak')%} yellow
'Super Off-peak')%} green
{%endif%}
layout: horizontal
entity: input_select.power_cost
primary: >-
The windows are
{%if is_state('input_select.window_status',
'Closed')%} closed
{%elif is_state('input_select.window_status',
'Open')%} open
{%else%} ERROR
{%endif%}
{%if is_state('input_boolean.window_matches',
'off')%}
and should be
{%if is_state('input_select.windows_suggestion',
'Should Be Closed')%} closed
{%elif
'Should Be Open')%} open
{%else%} ERROR
{%endif%}
{%elif is_state('input_boolean.window_matches',
'on')%}
{%else%} ERROR
{%endif%}
secondary: ''
icon: >
'Closed')%} mdi:window-closed
'Open')%} mdi:window-open
{%endif%}
tap_action:
action: call-service
service: script.window_button
data: {}
target: {}
hold_action:
action: more-info
double_tap_action:
action: none
icon_color: >-
'on')%} green
'off')%} red
{%else%} white
{%endif%}
layout: horizontal
entity: input_select.window_status
primary: Is Dark Outside
secondary: >
{%if is_state('input_boolean.is_dark_outside',
'on')%} Yes
{%else%} No
{%endif%}
icon: >
'on')%} mdi:weather-night
{%else%} mdi:weather-sunny
{%endif%}
tap_action:
action: none
hold_action:
action: more-info
double_tap_action:
action: none
icon_color: >-
'on')%} indigo
{%else%} yellow
{%endif%}
entity: input_boolean.is_dark_outside
primary: Echo
secondary: >-
{%if is_state('switch.echo_do_not_disturb',
'on')%} Do Not Disturb
{%else%} Normal
{%endif%}
icon: >
'on')%} mdi:volume-mute
{%else%} mdi:volume-source
{%endif%}
entity: switch.echo_do_not_disturb
double_tap_action:
action: none
icon_color: >-
'on')%} red
{%else%} green
{%endif%}
tap_action:
service: switch.toggle
service_data: {}
entity_id: switch.echo_do_not_disturb
hold_action:
action: more-info
primary: Guest Mode
secondary: >
{%if is_state('input_boolean.guest_mode',
'on')%} On
{%else%} Off
{%endif%}
icon: >
'on')%} mdi:account-group
{%else%} mdi:account
{%endif%}
tap_action:
action: toggle
hold_action:
action: more-info
double_tap_action:
action: none
icon_color: >-
'on')%} green
{%else%} red
{%endif%}
entity: input_boolean.guest_mode
cards:
title: Cleaning
primary: Has the Upstairs Been Vacuumed
secondary: >
{%if is_state('input_select.upstairs_vacuumed',
'Yes')%} Yes
{%else%} No
{%endif%}
icon: >
'Yes')%} mdi:check-bold
{%else%} mdi:close
{%endif%}
tap_action:
service: automation.trigger
service_data: {}
entity_id: automation.manual_clean
hold_action:
action: more-info
double_tap_action:
action: none
icon_color: >-
'Yes')%} green
{%else%} red
{%endif%}
entity: input_select.upstairs_vacuumed
primary: Has the Downstairs Been Vacuumed
secondary: >
{%if
is_state('input_select.downstairs_vacuumed',
'Yes')%} Yes
{%else%} No
{%endif%}
icon: >
{%if
{%else%} mdi:close
{%endif%}
tap_action:
entity_id: automation.vacuum_downstairs_manual_clean
data: {}
hold_action:
action: more-info
double_tap_action:
action: none
icon_color: >-
{%if
'Yes')%} green
{%else%} red
{%endif%}
entity: input_select.downstairs_vacuumed
title: Wash
cards:
primary: Washer
secondary: >-
{% if is_state("sensor.washer", "on") %}
Running {{ state_attr("sensor.washer",
"current_course") }}
Currently {{ state_attr("sensor.washer",
"run_state") }}
"initial_time") }} total
"remain_time") }} to go {% else %} Off {%
endif %}
icon: mdi:washing-machine
entity: sensor.washer
multiline_secondary: true
icon_color: >-
{{ "indigo" if is_state("sensor.washer",
"on") else "" }}
tap_action:
action: more-info
primary: Dryer
secondary: >-
{% if is_state("sensor.dryer", "on") %}
Running {{ state_attr("sensor.dryer",
Currently {{ state_attr("sensor.dryer",
"run_state") }}
{{ state_attr("sensor.dryer", "remain_time")
}} to go {% else %} Off {% endif %}
icon: mdi:tumble-dryer
entity: sensor.dryer
icon_color: >-
{{ "indigo" if is_state("sensor.dryer",
"on") else "" }}
tap_action:
action: more-info
cards:
title: Garage Doors
- type: custom:mushroom-cover-card
entity: cover.primarygaragedoor
entity: cover.secondarygaragedoor
cards:
entity: input_boolean.display_1080ph_loop
layout: vertical
tap_action:
action: toggle
hold_action:
action: more-info
double_tap_action:
action: none
icon: >-
{%if is_state('input_boolean.display_1080ph_loop', 'on')%}
mdi:repeat
{%else%} mdi:repeat-off
{%endif%}
icon_color: >-
green
{%else%} red
{%endif%}
layout: vertical
tap_action:
service: input_select.select_option
service_data:
option: Ian Calendar
entity_id: input_select.display_1080ph_element
hold_action:
action: more-info
double_tap_action:
action: none
icon: >-
{%if is_state('input_select.display_1080ph_element', 'Ian
Calendar')%} mdi:calendar-blank-outline
{%else%} mdi:calendar-remove
{%endif%}
icon_color: >-
Calendar')%} green
{%else%} red
{%endif%}
layout: vertical
tap_action:
service_data:
option: General Information
hold_action:
action: more-info
double_tap_action:
action: none
icon: >-
{%if is_state('input_select.display_1080ph_element', 'General
Information')%} mdi:information-outline
{%else%} mdi:information-off-outline
{%endif%}
icon_color: >-
Information')%} green
{%else%} red
{%endif%}
layout: vertical
tap_action:
service_data:
option: Lights
hold_action:
action: more-info
double_tap_action:
action: none
icon: >-
'Lights')%} mdi:lightbulb-group-outline
{%else%} mdi:lightbulb-group-off-outline
{%endif%}
icon_color: >-
'Lights')%} green
{%else%} red
{%endif%}
layout: vertical
tap_action:
service_data:
option: House State
hold_action:
action: more-info
double_tap_action:
action: none
icon: >-
{%if is_state('input_select.display_1080ph_element', 'House
State')%} mdi:home-outline
{%else%} mdi:home-remove-outline
{%endif%}
icon_color: >-
State')%} green
{%else%} red
{%endif%}
cards:
primary: ''
secondary: ''
icon: mdi:dice-d20-outline
layout: vertical
tap_action:
action: navigate
navigation_path: https://ijha.duckdns.org:8123/lovelace-dnd/dnd
hold_action:
action: none
double_tap_action:
action: none
entity: input_boolean.dnd_mode
fill_container: false
icon_color: yellow
primary: ''
secondary: ''
icon: mdi:format-list-checks
icon_color: yellow
layout: vertical
tap_action:
action: navigate
navigation_path: https://ijha.duckdns.org:8123/lovelace-lists/0
primary: ''
secondary: ''
icon: mdi:cctv
icon_color: yellow
fill_container: true
layout: vertical
tap_action:
action: navigate
navigation_path: https://ijha.duckdns.org:8123/lovelace-cameras/home
hold_action:
action: none
double_tap_action:
action: none
primary: ''
secondary: ''
icon: mdi:cog
icon_color: yellow
layout: vertical
tap_action:
action: navigate
navigation_path: https://ijha.duckdns.org:8123/lovelace-settings/0
hold_action:
action: none
double_tap_action:
action: none
primary: ''
secondary: ''
icon: ''
icon_color: ''
layout: vertical
