Nope, definitely a seperate issue with completely different symptoms. Please use the automation trace to debug your issue and post in a separate topic.
It is a separate issue, please do as Tom says and create a new thread. This whole thread is related to issues firing service calls causing automations to hang and you’re here talking about a missed condition.
I know that this is a separate issue and i do not need help on this issue as it resolved by itself.
My mentioned of this incident was only to further add to the ammunition that @tom_l will escalate.
the upgrade to 2023.8.2 is creating inconsistent behaviour in automations not only the disappearance of the automation in the GUI that started this thread (and i think i resolved it as mentioned above).
but communications between device (this i will open a different thread) for example in my light control automation (the one mentioned above) at dusk when the first instance of the detection of the condition (lux less than 3) the shelly light will take up to 4 second to light up. after that the light turns on immediately)
As i said this is a seperate item an i will open an other thread for this. However I still smell the footprint of the upgrade to 2023…8.2, Because it was working fine before the upgrade
