Debugs:
2018-05-08 11:35:14 DEBUG (Thread-23) [mysensors.gateway_tcp] Received 6;1;1;0;2;0
6;1;1;0;3;0
6;1;1;0;40;000000
6;2;1;0;48;1
2018-05-08 11:35:14 DEBUG (Thread-23) [homeassistant.components.mysensors] Node update: node 6 child 1
2018-05-08 11:35:14 DEBUG (Thread-23) [homeassistant.components.mysensors] Invalid values: {2: '0'}: light platform: node 6 child 1: S_RGB_LIGHT requires value_type V_RGB @ data[40]
2018-05-08 11:35:14 DEBUG (Thread-23) [mysensors] Handle queue with call <bound method Gateway.logic of TCPGateway>(('6;1;1;0;2;0',), {}) took 0.211 seconds
2018-05-08 11:35:14 DEBUG (Thread-23) [homeassistant.components.mysensors] Invalid values: {2: '0', 3: '0'}: light platform: node 6 child 1: S_RGB_LIGHT requires value_type V_RGB @ data[40]
2018-05-08 11:35:14 DEBUG (Thread-23) [mysensors] Handle queue with call <bound method Gateway.logic of TCPGateway>(('6;1;1;0;3;0',), {}) took 0.246 seconds
2018-05-08 11:35:14 ERROR (Thread-23) [mysensors] Not a valid message: Not valid message sub-type: 40 for dictionary value @ data['sub_type']
2018-05-08 11:35:14 DEBUG (Thread-23) [mysensors] Handle queue with call <bound method Gateway.logic of TCPGateway>(('6;1;1;0;40;000000',), {}) took 0.206 seconds
2018-05-08 11:35:14 ERROR (Thread-23) [mysensors] Not a valid message: Not valid message sub-type: 48 for dictionary value @ data['sub_type']
2018-05-08 11:35:14 DEBUG (Thread-23) [homeassistant.components.mysensors] Node update: node 6 child 2
2018-05-08 11:35:14 DEBUG (Thread-23) [homeassistant.components.mysensors] No child values for node 6 child 2
2018-05-08 11:35:14 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-05-08 11:35:14 DEBUG (Thread-23) [mysensors] Handle queue with call <bound method Gateway.logic of TCPGateway>(('6;2;1;0;48;1',), {}) took 0.194 seconds
From the node:
TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
TSF:MSG:READ,0-0-6,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
TSF:MSG:SEND,6-6-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
TSF:MSG:READ,0-0-6,s=255,c=3,t=6,pt=0,l=1,sg=0:I
TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=0,st=OK:RGB Strip Controler
TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:0.1
TSF:MSG:SEND,6-6-0-0,s=1,c=0,t=26,pt=0,l=9,sg=0,ft=0,st=OK:RGB Strip
TSF:MSG:SEND,6-6-0-0,s=2,c=0,t=23,pt=0,l=12,sg=0,ft=0,st=OK:RGB Strip FX
MCO:REG:REQ
TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
TSF:MSG:READ,0-0-6,s=255,c=3,t=27,pt=1,l=1,sg=0:1
MCO:PIM:NODE REG=1
MCO:BGN:STP
MySensors Node Setting up...
... complete!
MCO:BGN:INIT OK,TSP=1
TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:0
TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=40,pt=0,l=6,sg=0,ft=0,st=OK:000000
TSF:MSG:SEND,6-6-0-0,s=2,c=1,t=48,pt=1,l=1,sg=0,ft=0,st=OK:1
and the JSON generated:
{"0": {"battery_level": 0, "sketch_version": "0.5", "children": {}, "type": 18, "protocol_version": "2.2.0", "sketch_name": "MySensors Ethernet Gatewa", "sensor_id": 0}, "1": {"battery_level": 0, "sketch_version": "0.1", "children": {"1": {"id": 1, "description": "RGB Strip", "values": {}, "type": 26}}, "type": 17, "protocol_version": "2.1.1", "sketch_name": "RGB Strip Controler", "sensor_id": 1}, "2": {"battery_level": 0, "sketch_version": "0.5", "children": {"0": {"id": 0, "description": "Humidity", "values": {"1": "19.7"}, "type": 7}, "1": {"id": 1, "description": "Temperature", "values": {"0": "85.6"}, "type": 6}, "2": {"id": 2, "description": "Motion Sensor", "values": {"16": "0"}, "type": 1}, "3": {"id": 3, "description": "Light Level", "values": {"23": "69"}, "type": 16}, "6": {"id": 6, "description": "TX RSSI", "values": {"48": "-256"}, "type": 23}, "7": {"id": 7, "description": "RX RSSI", "values": {"48": "-78"}, "type": 23}, "8": {"id": 8, "description": "Uplink Quality RSSI", "values": {"48": "0"}, "type": 23}}, "type": 17, "protocol_version": "2.2.0", "sketch_name": "MultiSensor (Feather)", "sensor_id": 2}, "3": {"battery_level": 0, "sketch_version": "0.5", "children": {"0": {"id": 0, "description": "Humidity", "values": {"1": "22.9"}, "type": 7}, "1": {"id": 1, "description": "Temperature", "values": {"0": "73.2"}, "type": 6}, "2": {"id": 2, "description": "Motion Sensor", "values": {"16": "0"}, "type": 1}, "6": {"id": 6, "description": "TX RSSI", "values": {"48": "-256"}, "type": 23}, "7": {"id": 7, "description": "RX RSSI", "values": {"48": "-43"}, "type": 23}, "8": {"id": 8, "description": "Uplink Quality RSSI", "values": {"48": "0"}, "type": 23}, "9": {"id": 9, "description": "Battery Voltage", "values": {"38": "3.8"}, "type": 30}}, "type": 17, "protocol_version": "2.2.0", "sketch_name": "MultiSensor (Feather)", "sensor_id": 3}, "4": {"battery_level": 0, "sketch_version": "0.5", "children": {"0": {"id": 0, "description": "Humidity", "values": {"1": "20.4"}, "type": 7}, "1": {"id": 1, "description": "Temperature", "values": {"0": "69.4"}, "type": 6}, "2": {"id": 2, "description": "Motion Sensor", "values": {"16": "0"}, "type": 1}, "6": {"id": 6, "description": "TX RSSI", "values": {"48": "-256"}, "type": 23}, "7": {"id": 7, "description": "RX RSSI", "values": {"48": "-46"}, "type": 23}, "8": {"id": 8, "description": "Uplink Quality RSSI", "values": {"48": "0"}, "type": 23}, "9": {"id": 9, "description": "Battery Voltage", "values": {"38": "4.1"}, "type": 30}}, "type": 17, "protocol_version": "2.2.0", "sketch_name": "MultiSensor (Feather)", "sensor_id": 4}, "5": {"battery_level": 0, "sketch_version": "0.5", "children": {"0": {"id": 0, "description": "Humidity", "values": {"1": "22.0"}, "type": 7}, "1": {"id": 1, "description": "Temperature", "values": {"0": "77.9"}, "type": 6}, "2": {"id": 2, "description": "Motion Sensor", "values": {"16": "0"}, "type": 1}, "6": {"id": 6, "description": "TX RSSI", "values": {"48": "-256"}, "type": 23}, "7": {"id": 7, "description": "RX RSSI", "values": {"48": "-53"}, "type": 23}, "8": {"id": 8, "description": "Uplink Quality RSSI", "values": {"48": "0"}, "type": 23}, "9": {"id": 9, "description": "Battery Voltage", "values": {"38": "4.1"}, "type": 30}}, "type": 17, "protocol_version": "2.2.0", "sketch_name": "MultiSensor (Feather)", "sensor_id": 5}, "6": {"battery_level": 0, "sketch_version": "0.1", "children": {"1": {"id": 1, "description": "RGB Strip", "values": {"2": "0", "3": "0"}, "type": 26}, "2": {"id": 2, "description": "RGB Strip FX", "values": {}, "type": 23}}, "type": null, "protocol_version": "1.4", "sketch_name": "RGB Strip Controler", "sensor_id": 6}}
