I found some curious behavior that would be nice to get some insight on.
The situation:
I have a Zwave outdoor GE outlet. It’s one of those inline plug ones. I use it for Christmas and halloween lights.
In entity registry it’s set to have a name “zwave.outdoor_1” with a corresponding switch “switch.outdoor_1”
These two relate back to the zwave node ID and work correctly.
When not in use this outlets get unplugged. During that time it’s reported as a dead node.
But what is odd is the switch corresponding to it; “switch.outdoor_1” seems to randomly change state over time. This is odd as the physical device isn’t available.
If I plug it back in after a few minutes it works as expected and the status for the switch matches the actual state.
If I remove the switch after several hours I start to get the phantom state updates.
To me this seems like some sort of odd un-intialized variable issue; or memory being overwritten to cause the state change. I even see the state change in the logbook when it happens.
For a well-behaving node being “Dead” is not a problem. When you plug it back in it will send a packet to the controller and the controller will consider it “live” again.
Do you have a poll configured for that switch? Either a z-wave poll (which should be fine) or some other automation?
