I have two wall panels, running Fully on Amazon Fire HD7 tablets. They both use the same mount and I have confirmed that the mounting bracket does not touch any portion of the screen (you’ll see why in a moment). The only functional difference between the two panels is the account they are using and the dashboard that they display.
On a regular basis (read- 2-3 times per day) a random more info screen will pop up on the tablet in the living room, sometimes the garage door status, and other times it’ll be the weather or switch status. Thinking that the tablet had some sort of issue with the touch sensor I swapped the tablets, changing only the login account which controls the dashboard that the tablet displays.
The issue follows the login account to the living room tablet.
Does anyone have any ideas on what to look at?
The entities that popup don’t seem to have anything to do with any of my addons but for reference my only lovelace add-ons are
- Atomic Calendar
- Battery Card
- Lovelace Home Feed
- Mini Graph card
