I have set up a light with a restful api.
I can turn it on and off, and adjust brightness from the interface.
But if I try and turn the light on with a set brightness i Node-Red it fails to set the brightness?
My ‘light’ is a magicmirror, there was an integration to it, but that has died.
So I wanted to set up my own ‘integration’ via a RESTful(ish) API to the module called Remote-control in MagicMirror.
First of I’ve created three rest_commands:
turn_on_bathroom_monitor:
url: "http://1.2.3.4:8080/api/monitor/on?apiKey=xxx"
method: get
turn_off_bathroom_monitor:
url: "http://1.2.3.4:8080/api/monitor/off?apiKey=xxx"
method: get
set_bathroom_monitor_brightness:
url: "http://1.2.3.4:8080/api/brightness/{{ brightness }}?apiKey=xxx"
method: get
Then I made two sensors
- platform: rest
name: Bathroom Monitor state
resource: "http://1.2.3.4:8080/api/monitor/?apiKey=xxx"
method: GET
value_template: "{{ value_json.monitor }}"
- platform: rest
name: Bathroom Monitor brightness
resource: "http://1.2.3.4:8080/api/brightness/?apiKey=xxx"
method: GET
value_template: "{{ (value_json.result | float * 2.55) | round(0) }}"
scan_interval: 20
So now I can set values and read values.
I then made a light:
bathroom_monitor:
friendly_name: "MagicMirror Bathroom Monitor"
unique_id: "e2d0359d-aafe-4140-a234-f59054e93f30"
turn_on:
- action: rest_command.turn_on_bathroom_monitor
- delay: 1
- action: homeassistant.update_entity
entity_id: sensor.bathroom_monitor
turn_off:
- action: rest_command.turn_off_bathroom_monitor
- delay: 1
level_template: "{{ states('sensor.bathroom_monitor_brightness') | int }}"
set_level:
- action: rest_command.set_bathroom_monitor_brightness
data_template:
brightness: "{{ (brightness / 2.55) | int }}"
- delay: 1
entity_id: sensor.bathroom_monitor_brightness
icon_template: >-
mdi:mirror-rectangle
Thanks to @tom_l I got the long delay in updates of the state fixed.
So now I can control the monitor, turn it on/off and brightness.
Just what I wanted.
But if I turn the ‘light’ on in Node-red with a JSON data field with brightness, it doesn’t work? If I omit the brightness it works.
When I look in developer tools, the light is reported like this:
supported_color_modes:
- brightness
color_mode: null
brightness: null
icon: mdi:mirror-rectangle
friendly_name: MagicMirror Bathroom Monitor
supported_features: 0
So is it that it doesn’t support brightness_pct, but only brightness?
