Odroid C2 - Blue Led
Hello, it is possible to change the function of the blue led.
I would like to see the emmc access instead of the heartbeat.
I have only found the following link
Thanks for the link. I’m a Windows guy, but the only solution left for me would be to try and run Ubuntu or similar with Home Assistant running in a Docker window. I’m not doing it. The Terminal & SSH Add-on in HA OS gives an error after the su command and the following echo command: echo none > /sys/class/leds/n2:blue:heartbeat/trigger. “Read Only”.
My research tells me that HA is a Linux version of Ubuntu with some Alpine thrown in.
