I am at a total loss here, I just purchased a preloaded ODROID from ameridroid and set it up and did some updates and now it is not appearing on my network at all and http://homeassistant.local:8123/ isn’t working. How do I completely flash this thing and start over? Or should I return?
a micro USB cable… one that isn’t 10 years old you dug out of a drawer somewhere. I say that because my efforts to flash were frustrated by using a crappy cable. A new one from amazon basics worked like a charm.
An allen wrench to open the case
Balena Etcher to write the firmware
How it works is that there’s a little switch you can flip inside the case that makes the Blue look like a drive to windows. You flip the switch, booth the device, write the firmware with Etcher, then flip the switch back again so it boots normally into HA.
The whole thing is easy once you have a decent cable and understand the SPI switch.
Ya I got it, it turned out to be a bad cable which completely died during update, which bricked it. I was able to flash it and it’s working now but not under homeassistant.local
