ODROID N2+ don't boot
I received my ODROID N2+ with 64GB eMMC Module N2 and I did a fresh install of Home Assistant with this link.
It worked well but during a reboot, I have this message:
Card did not respond to voltage select! : -110
unable to select a mode : -5
MMC Device 2 not found
no mic device at slot 2
However the module works perfectly when I use the USB adapter and connect it to my Linux Debian.
I have configured the switch on the Odroid N2 on MMC.
With Ubuntu OS Image I have no problem…
https://dn.odroid.com/S922X/ODROID-N2/Ubuntu/ubuntu-20.04-4.9-minimal-odroid-n2-20220228.img.xz
Do you have the same problem?
Regards
I just retested by installing the HA image haos_odroid-n2-13.2.img with balenaEtcher but my ODROID does not boot.
I tested with the ODROID image ubuntu-22.04-4.9-mate-odroid-n2-20220629.img && ubuntu-22.04-4.9-mate-odroid-n2-20220629.img and I have no boot problem.
Isn’t there a problem on the HA image with an eMMC module on an ODROID N2+?
I took a picture at boot time with the HA image
Should I open an issue? or does it already exist?
