I have several Wemos units in the same config, dual base with D1 in one slot and SHT30 board with stacked OLED board in the other slot.
I do not have a 3D printer, but our library does. I am looking for a box design that will hold the base and has an opening for the display and vent slots all the way around. Surely someone here has made one for a similar stack of Wemos parts…
I did look at that one. I could cut on the lid and maybe get it to work. I find that for thermal sensors, getting the SHT30 off the top of the Wemos makes it more accurate. It appears that the Wemos makes enough heat to affect the SHT30. It is not always linear…
There was a modular stacking set that looked good, but the fit was so horrible that I had to glue it all together…
I have sent a couple of other designs to the library for printing, will get them in a few days.
I only bring it up because my 11 yo already shorted one out. She was curious and picked it up and put it back down on a metal surface! She reported smoke and stink!
Yep I’ve blown a few and they do smoke and stink , I have both single stack and dual stack versions but currently no cases, if you find any that fit report back as I need to source some myself It might be worth going to a professional company as they may have better materials/printers and will probably be more accurate.
This one looks interesting for a dual base…
Not sure about the infill thing but I wonder if it makes a difference how it’s rotated on the base, I would assume they should be rotated to be flat on base and therefore there should not be much infill in a box shape?
