Here some logging. The last attempt is without the portname and it doesnt make connection with a different error.
The first three attempts make connection to the host, but CalDav raises the “object has no attribute 'hostname”-error.
url: http://192.168.0.56:1080/users/[email protected]/calendar
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 150, in _async_setup_platform
await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 442, in wait_for
return fut.result()
File "/usr/src/homeassistant/homeassistant/components/caldav/calendar.py", line 74, in setup_platform
calendars = client.principal().calendars()
File "/usr/local/lib/python3.7/site-packages/caldav/objects.py", line 417, in calendars
return self.calendar_home_set.calendars()
File "/usr/local/lib/python3.7/site-packages/caldav/objects.py", line 396, in calendar_home_set
'{urn:ietf:params:xml:ns:caldav}calendar-home-set']
File "/usr/local/lib/python3.7/site-packages/caldav/objects.py", line 405, in calendar_home_set
if (sanitized_url.hostname and
AttributeError: 'NoneType' object has no attribute 'hostname'
url: http://server.domain:1080/users/[email protected]/calendar
return fut.result()
url: http://127.0.0.1:1080/users/[email protected]/calendar
return fut.result()
url: http://127.0.0.1/users/[email protected]/calendar
return fut.result()
File "/usr/local/lib/python3.7/site-packages/caldav/davclient.py", line 118, in principal
return Principal(self)
File "/usr/local/lib/python3.7/site-packages/caldav/objects.py", line 370, in __init__
cup = self.get_properties([dav.CurrentUserPrincipal()])
File "/usr/local/lib/python3.7/site-packages/caldav/objects.py", line 219, in get_properties
response = self._query_properties(props, depth)
File "/usr/local/lib/python3.7/site-packages/caldav/objects.py", line 129, in _query_properties
return self._query(root, depth)
File "/usr/local/lib/python3.7/site-packages/caldav/objects.py", line 161, in _query
url, body, depth)
File "/usr/local/lib/python3.7/site-packages/caldav/davclient.py", line 133, in propfind
{'Depth': str(depth)})
File "/usr/local/lib/python3.7/site-packages/caldav/davclient.py", line 237, in request
auth=auth, verify=self.ssl_verify_cert)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='127.0.0.1', port=80): Max retries exceeded with url: /users/[email protected]/calendar/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7fc6ba2f2a10>: Failed to establish a new connection: [Errno 111] Connection refused'))
