This is my working version for automating desk lamp.
I begin to do my home-office work early, at about 10hs and usually I do finish it around 18hs. Sometimes it can be even later, like 19hs or 20hs. While I’m working I may be deep involved into some task or I may be in a long video meeting so I don’t want to open some panel to switch on my desk light. I want it to just happen.
So, the rules:
- I want it to turn on the light anytime between 1:15 hours before sunset (I do have some mountains here, it gets dark before sunset).
- I want to have a panel switch to disable automation, easy for any user to find it.
- How do I know if I’m on the desk and not somewhere else? The most precise way I found it is by the number of monitors. On my desk my second monitor is on, else, not. It also helps when I just close the Macbook lid, it means, no more work.
- I want to be able to anytime, manually switch on or switch off the light. So I don’t want periodic trigger.
- I want it to turn off the light in case I’m deep working on very early morning, I shouldn’t but, better to hate it as a rule! So, I want switch off 1:15 hours after sunrise.
So here is my automation rule. It took me quite a bit of time, it may have a lot of opportunities for improvement (and all of those would be welcomed!).
And if you find it useful for yourself, just grab it!
- id: '1651070652453'
alias: Abajour automático
description: ''
- platform: state
entity_id: sensor.macbook_pro_de_aline_displays
- platform: sun
event: sunset
offset: -01:15:00
condition:
- condition: state
entity_id: switch.abajour_automation_switch
state: 'on'
- choose:
- conditions:
- condition: or
conditions:
- condition: sun
after: sunset
after_offset: -01:15:00
- condition: sun
before: sunrise
before_offset: 01:15:00
- condition: or
conditions:
- condition: template
value_template: '{{ is_state("sensor.macbook_pro_de_aline_displays", "2")
value_template: '{{ trigger.to_state.state == "2" }}'
sequence:
- service: switch.turn_on
- conditions:
- condition: or
conditions:
- condition: sun
after: sunrise
after_offset: 01:15:00
- condition: sun
before: sunset
before_offset: -01:15:00
- condition: or
conditions:
value_template: '{{ not is_state("sensor.macbook_pro_de_aline_displays",
"2") }}'
value_template: '{{ trigger.from_state.state == "2" }}'
sequence:
- service: switch.turn_off
