Official Arlo iPhone app keeps logging out after Aarlo logs in
I have been using the Aarlo integration for a while and it worked fine until a couple of months ago.
Since then the official Arlo iPhone app keeps logging out with this message:
What could be a solution?
On the integrations github it says this:
Aarlo needs a dedicated Aarlo login. If you try to reuse an existing login - for example, the login from the Arlo app on your phone - the app and this component will constantly fight to log in.
Before this it says “If you are replacing the original Arlo component you don’t need to do this step.”. I’m not sure how this makes sense (I don’t have Arlo). If the mobile app and Aarlo are both using the same logon, how has that anything to do whether or not you also use original Arlo integration. I would just create another logon for Aarlo regardless.
You might be onto something, I’ll give it a try. Thanks!
I added a new user with a different password. Even when I use that when logging in the app (where I use my standard account) keeps login out. So that was not the problem. Other tips?
I know this is an old thread, however, adding this reply for tracking reasons if anybody else stumbles across this issue.
Just got my RPi5 today and installed HA. When I did the first Aarlo integration I was using my “main” Arlo account. Obviously I got continuously logged out from the app. I then created a new Arlo account for the Aarlo integration. However, even after setting up everything, I still got kicked out from the app on my phone. After having a look at the code, I deleted the aarlo.pickle and session.pickle file at /homeassistant/.aarlo. They do not seem to get overwritten if you change the config yaml if there was any previous successful connection attempt. This means it will continue to use the initial account. After I deleted those files I restarted HA and everything works like a charm.
