sorry, should have posted logs.
Checked the blog post (will check there first next time) and none of the breaking changes affect me.
ErrorWarningSystemArrayLogin
File "/usr/local/lib/python3.6/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/usr/local/lib/python3.6/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/usr/src/app/homeassistant/__main__.py", line 374, in <module>
sys.exit(main())
File "/usr/src/app/homeassistant/__main__.py", line 349, in main
args = get_arguments()
File "/usr/src/app/homeassistant/__main__.py", line 90, in get_arguments
import homeassistant.config as config_util
File "/usr/src/app/homeassistant/config.py", line 26, in <module>
from homeassistant.util.yaml import load_yaml, SECRET_YAML
File "/usr/src/app/homeassistant/util/yaml.py", line 16, in <module>
import credstash
File "/usr/local/lib/python3.6/site-packages/credstash.py", line 55, in <module>
'RIPEMD': hashes.RIPEMD160,
AttributeError: module 'cryptography.hazmat.primitives.hashes' has no attribute 'RIPEMD160'
sys.exit(main())
import credstash
sys.exit(main())
import credstash
sys.exit(main())
import credstash
sys.exit(main())
import credstash
sys.exit(main())
import credstash
