It has been working fine - both official Volvo Integration and HACS Volvo Integration. I got a warning, I think when I upgraded to 2025.12.2 that the HACS Volvo Integration repository was being removed so I in turn deleted that integration given the duplication (I think this was yesterday).
However, today I was told I need to re-authenticate the official Volvo integration - despite it having worked uninterrupted for quite a while, including immediately after deleting the HACS Volvo Integration. When I try to authenticate, I get to the “Sign in with your Volvo ID” page, enter my Volvo username and password but then get an “Oops…an error occurred, Unexpected response Forbidden”, which is on a Nabu Casa page.
For the record, I don’t use Nabu Casa for remote access and actually use Cloudflared.
I’m using Nabu Casa and get the same error when re-authenticating or setting up the integration fresh, after logging in with Volvo ID I just get the same “Oops… an error occured
Same problem here, Volvo integration is not allowing sign in and seems to be Nabu related! forcing nabu subs, is a deal breaker, hoping that’s not the case, as a very sad future if HA goes down that route with this and other integrations.
I confirm the issue, version 2025.12.2, re-authorization required. After granting app permissions, I receive the message: Oops… an error occurred
Unexpected response: Forbidden.
In the meantime, I’m running various tests to determine what might be causing this.
Also the same here, everything was fine using 11.x of hass core. I also tried to uninstall the integration + updating core to 12.2 and I also get “Unexpected response Forbidden” from nabu.
