Offline map view
Hi, i have a wall mounted tablet/dashboard sitting on a LAN only VLAN configured in PFSENSE, my only gripe is that i am unable download a local map to show our locations (no access to web) is there a way i can allow a firewall rule to access just the map server or even better download the local area to the tablet for offline viewing? Thanks
I have the same question/use case. @Johnston19910 would love to know if you figured out a solution or if anyone else has one.
thanks
Hi Frank,
Yes after many failed attempts I finally figured it out, are you also using pfsense?
Yes, I do use pfsense. Anything you can share would be greatly appreciated.
Long short create a firewall alias that allows access to the below and then create a firewall rule that passes that alias through,
Also allow the device in the no internet VLAN to allow port 53 for DNS services
Hope that helps if not I can write up better instructions tomorrow when I’m at my laptop
Thank you, that did the trick. Its a good workaround until one day we either
  1. get local map support
  2. use the server to proxy web requests (maps).
no more blank boxes when looking at the map :smiley:
