Hi there folks. As you know, I migrated my Pi3 instance to Intel NUC recently as documented here My steps to success for Hass.io on Intel NUC.
Sadly for 2nd time, the NUC refuses to boot after a resin reboot command and is now displaying this on the screen.
root '/dev/disk/by-label/resin-rootA' doesn't exist or does not contain /dev
Can anyone advise on how I could fix that? I can remove the SSD and explore in Linux Live if that helps. System was running Hass.io 0.64.1 and I tried to update the host system which did not work.
I then decided to move the physical location of the NUC so issued a ‘SHUTDOWN’ command from the GUI and this is when it failed to start. As this is my live system I’m in a bit of a panic now to try and get this working before the wife comes home
