I have a sub flow that sends email. I needed to change its server address, and when I go into the node (before even changing it), I see an error indicator (red triangle) which reports “Invalid token”.
I don’t even know where to start. The node has no significant data in it, just a name, blank to address (provided by payload), server as explicit IP, port as 25 (no quotes), not secure, and auth type none (it’s a local email relay).
What token?
I deployed it anyway and it does work, but now that I’ve touched it, every deployment using it complains.
Home Assistant 2024.4.3, Node red 3.1.9 / 17.0.12 (appears current on both).
I regret that I tried replacing it before looking at it in the manage palette, foolishly, so I cannot tell if it was previously up to date (and it’s in a subflow so the only occurrence).
I also now know I have to review those and update – I (even more foolishly) thought that updating node red itself was updating all the nodes, but apparently not. Though I’m a bit terrified of going through and just updating all that I see are out of date, almost every time node red updates something breaks, can’t imagine what all those will do. But I guess I should.
Thank you. Wish I understood what was broken – since if it was out of date it should not have changed since last use (when it did not have that error). But… working now, I’ll take it as a win.
