Old entities popping up
configuring my water consumption dashboard, HA proposes me some old entities (very old) that i deleted time ago.
So you’d say: look for them in entities and delete them. They are not there.
So you’d say: check if they are at least in the history tab. They are not there.
So you’d say: look for them as orphaned entity, so in config/.storage/core.entity_registry. THEY ARE NOT EVEN THERE!
i don’t know where to look for them more than this :slight_smile:
ideas? (obviously i rebooted HA a lot of times…)
thanks
I’d expect them to have long term statistics, so I guess you should be able to find them in Developer tools, statistics (which is not the same as the History tab).
It is good that you can still select them, so you can look into their history in the energy dashboard. For that they need to remain configured in the energy dashboard, even if they do not produce any new data.
you are the man!
thank you!
those were not real sensors, just orphaned entities coming from old integration tests, damn i have A LOT of entities to delete with long term statistics!
thanks!
