Old iPad with HA
Hello everyone. Does anyone know how to use an old iPad with HA. It stopped working for me a while ago. HA stays in the logo and browsers are no longer updated. Thank you
I’m using an old iPad Mini Retina with the HA iOS app, and not having any problems. Have you tried dragging down on the page to refresh?
Yes. The app sometimes runs and other times it stays on the splash screen. Then I tried with many browsers and what happens is that the page starts fine but after a while it refreshes and the screen remains black
Maybe try a restart - hold both the home and power buttons down until you see the Apple logo.
Do you say do a soft reset? I did it. several browsers have already stopped having support. I am using safari
Some people are running Firefox as a docker container and using that. There is a thread somewhere about that
How a docker container installed where?
https://hub.docker.com/r/jlesage/firefox
This?
Maybe. As I said there is a tread about it here somewhere
Thanks for the info. I did what you told me and it worked. Although there is a white border at the bottom, everything looks as before. Thank you very much
how is that done? do you host the firefox in docker container and then what?
Hello. I just followed this guide. Although it consumes many resources of the PC in which it is run, it works well. It is not the best option but it is the only one.
I’m confused here, does this suggest to run Docker on an iPad?
thanks,
BC
No. On a computer and iPad, you access it through an IP address. I don’t remember exactly, but it was something like this.
I found this in the meantime and set it up, it works rather well:
