Hey folks!
Was searching throughout the forum/reddit but cannot find anything similar.
I have Raspberry Pi 3B+ with Docker installed (not Compose), and right now it runs HA 2020.12.1
There is no supervisor and since it’s not HASS, I use this to update the system: sudo docker pull homeassistant/raspberrypi3-homeassistant:stable
The installation downloads all binaries, successfully unpacks/installs them and says it’s all good. Re-running this command says “Image is up to date”.
Restarting Docker and HA, then I head to Configuration > Info and I see Home Assistant 2020.12.1
The Docker hub package says it’s past 2021.3 and there were few packages uploaded yesterday (which my installation did unpack) https://hub.docker.com/r/homeassistant/raspberrypi3-homeassistant/tags?page=1&ordering=last_updated
Went through this cycle three times, nothing has changed. Am I missing something?
Thanks!
Please don’t recommend that without the warning that you will wake up to a dead HA system at some point. Breaking changes exist in every release, when one impacts your system an auto-update means HA won’t start.
Thank you for replies! Cannot use Docker Compose as it doesn’t compile under RPi 3B.
Also was trying to avoid re-installing the container - won’t I have to reconfigure all networking, usb dongles etc?
I use it to have an UI overview of all my containers and with Portainer it’s as easy as clicking a “recreate” button from the container config area and telling it to pull the latest image (three clicks total)
