OLED SH1106 with esphome
I have successfully connected SH1106 OLED with esp32.
Now I have two issues,
Used the following code
display:
  - platform: ssd1306_i2c
    model: "SH1106 128x64"
    address: 0x3C
    pages:
      - id: page1
        lambda: |-
         // Print WiFi Signal
         it.printf(0, 26, id(arial_14), "Wi-Fi: %.1f", id(wifi_sgnl).state);
         // Print time in HH:MM format
         it.strftime(0, 0, id(roboto), TextAlign::TOP_LEFT, "%H:%M", id(esptime).now());
         // Print Room humidity"(from xiaomi sensor)
         if (id(room_humidity).has_state()) {
         it.printf(127,62, id(roboto), TextAlign::BOTTOM_RIGHT, "%.1f%%", id(room_humidity).state);
         // Print Room temperature(from xiaomi sensor)
         if (id(room_temperature).has_state()) {
          it.printf(127, 0, id(Carrois_Gothic), TextAlign::TOP_RIGHT, "%.1f°C", id(room_temperature).state);
         // Print 29Gal temperature(from dallas sensor)
         if (id(dallas_temp).has_state()) {
          it.printf(0, 62, id(Carrois_Gothic), TextAlign::BOTTOM_LEFT, "%.1f°C", id(dallas_temp).state);
      - id: page2
        lambda: |-
          it.printf(64, 10, id(Kdam_Thmor_Pro), TextAlign::CENTER_HORIZONTAL, "%.1f°C", id(dallas_temp).state);
      - id: page3
        lambda: |-
          it.strftime(64, 10, id(Kdam_Thmor_Pro), TextAlign::CENTER_HORIZONTAL, "%H:%M", id(esptime).now());
      - id: page4
        lambda: |-
         // Print time from Human Readable uptime
          it.printf(60, 10, id(Merriweather), TextAlign::CENTER_HORIZONTAL, "%s", id(uptime_human).state.c_str());
# For example cycle through pages on a timer
interval:
  - interval: 3s
    then:
      - display.page.show_next: oled_display
      - component.update: oled_display
For uptime sensor used the following code
display:
    address: 0x3C
    pages:
      - id: page1
        lambda: |-
      - id: page2
        lambda: |-
      - id: page3
        lambda: |-
      - id: page4
        lambda: |-
interval:
  - interval: 3s
    then:
to make Human readable
- platform: uptime
    update_interval: 60s
    on_raw_value:
      then:
        - text_sensor.template.publish:
            state: !lambda |-
              int seconds = round(id(uptime_sensor).raw_state);
              int days = seconds / (24 * 3600);
              seconds = seconds % (24 * 3600);
              int hours = seconds / 3600;
              seconds = seconds % 3600;
              int minutes = seconds /  60;
              seconds = seconds % 60;
              return (
                (days ? to_string(days) + "d " : "") +
                (hours ? to_string(hours) + "h " : "") +
                (minutes ? to_string(minutes) + "m " : "") +
                (to_string(seconds) + "s")
              ).c_str();
You have not demonstrated that issue
A smaller font? or split the line with a newline character \n
[quote=“nickrout, post:2, topic:427790, full:true”]
I want to use a material icon like the one shown in the youtube video and screenshot I posted.
for simple google fonts I can add the following code and it will be added to esphome.
  # gfonts://family[@weight]
  - file: "gfonts://Roboto"
this is the code I am using for the fonts
# font defined
font:
  - file: "sh1106/arial.ttf"
  - file: "gfonts://Carrois Gothic"
  - file: "gfonts://Kdam Thmor Pro"
  - file: "gfonts://Merriweather"
I don’t want to use a smaller font, how to add the new line, this is the code I use to display the human-readable code
- id: page4
        lambda: |-
Like Nick said - insert a newline character where you want to split the line:
              return (
                (hours ? to_string(hours) + "h " : "") + "\n" +
              ).c_str();
I use the self-hosted font file, I haven’t been able to get gfonts:// working for the icons.
The font file containing many of the icons is here: material-design-icons/font at master · google/material-design-icons · GitHub
- platform: uptime
    on_raw_value:
      then:
            state: !lambda |-
              return (
                (minutes ? to_string(minutes) + "m " : "") + "\n" +
              ).c_str();
I tried this method but it doesn’t seem to work
Then you probably need to split up the uptime into several fields and apply the formatting to the printf statement.
And use a smaller font.
that will be the long solution, isn’t it?
but for the material design icon I can’t get it to work
I tried the icon copy-paste method described here but it didn’t work. Display materialdesign icons on ESPHome attached to screen - #5 by makai
got this error
[20:03:05][W][display:176]: Encountered character without representation in font: '\xf3'
[20:03:05][W][display:176]: Encountered character without representation in font: '\xb0'
[20:03:05][W][display:176]: Encountered character without representation in font: '\x94'
[20:03:05][W][display:176]: Encountered character without representation in font: '\x84'
[20:03:06][W][display:176]: Encountered character without representation in font: '\x94'
[20:03:06][W][display:176]: Encountered character without representation in font: '\x84'
[20:03:06][W][display:176]: Encountered character without representation in font: '\xf3'
[20:03:06][W][display:176]: Encountered character without representation in font: '\xb0'
[20:03:07][W][display:176]: Encountered character without representation in font: '\xf3'
[20:03:07][W][display:176]: Encountered character without representation in font: '\xb0'
[20:03:07][W][display:176]: Encountered character without representation in font: '\x94'
[20:03:07][W][display:176]: Encountered character without representation in font: '\x84'
What is your glyphs: line?
partially fixed with
  - file: 'sh1106/materialdesignicons-webfont.ttf'
    glyphs:
      - "\U000F1A80" # mdi-thermometer-water
      - "\U000F0510" # mdi-thermometer-lines
      - "\U000F0155" # mdi-clock-start
and for the lamda
  - id: page2
        lambda: |-
         // Print "Temp icon" in top left.
          it.printf(2, 0, id(icon_font), TextAlign::TOP_LEFT, "\U000F1A80" );
         // Print "Aquarium" in top center.
          it.printf(127, 0, id(roboto), TextAlign::TOP_RIGHT, "Aquarium");
Now at least I have got the icon on the screen, this is a slightly old picture, changed the code and moved the icon to the top left after this.
but getting this error every other second.
09:08:15	[W]	[display:176]
That is pointing to line 176 of the yaml (I think).
that is totally different code
  - platform: ble_client
    ble_client_id: itag_node
    name: "Black iTag btn"
    service_uuid: 'ffe0'
    characteristic_uuid: 'ffe1'
    notify: true
    update_interval: never
    on_notify:
      then:
        - binary_sensor.template.publish:
            state: ON
            state: OFF
    name: "Black iTag Battery"
    service_uuid: '180f'
    characteristic_uuid: '2a19'
    icon: 'mdi:battery'
    unit_of_measurement: '%'
161 to 182
Obviously not then! Other than very carefully checking that you have every glyph included I don’t know how else to debug this.
I am only using only using one icon i.e
but still facing this
It is working though isn’t it? You could just ignore.
it triggers my OCD :rofl:, seeing this yellow error again and again in logs.
I have that problem too. The solution is stop looking at the logs.
It somehow resolved on its own, or I removed some fonts due to space issues.
