while testing one of my projects, I’ve noticed, that oled ssd1306 remains blank when ESP32 is first connected to power. After RST, display initializes successfully and everything works fine.
Question is, how to debug such issue?
Also, I’ve noticed, that calling update() method of oled display causes Guru Meditation Error: Core  1 panic with subsequent reboot.
I’m attaching yaml file and also the exception caused by calling display update().
esphome:
  platformio_options:
    upload_speed: 921600
  on_boot:
    - priority: 0
      then:
        lambda: |-
            // turn on status led
            pinMode(22, OUTPUT);
            digitalWrite(22, LOW);
            delay(500);
esp32:
  board: lolin32_lite
  framework:
    type: arduino
# Enable logging
logger:
font:
  - file: "fonts/Roboto-Thin.ttf"
i2c:
  sda: GPIO16
  scl: GPIO17
  frequency: 800kHz
globals:
  - id: step
    type: int
    initial_value: "100000"
  - id: val
    type: int
    initial_value: "1000000"
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x32"
    update_interval: 50ms
    #auto_clear_enabled: false
    address: 0x3C
    lambda: |-
          it.printf(0, 0, id(roboto), "%d", id(val));
          it.printf(0, 16, id(roboto), "%d", (int)floor(log10(id(step))));
# A de-bounced GPIO is used to 'click'
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO19
      mode:
        input: true
        pullup: true
    filters:
      - invert:
      - delayed_on: 10ms
      - delayed_off: 10ms
    on_press:
      lambda: |-
          id(my_oled).update();
INFO Reading configuration bootfail.yaml...
INFO Starting log output from COM13 with baud rate 115200
[12:14:35][D][binary_sensor:036]: 'rotary_encoder_btn': Sending state ON
[12:14:35]Guru Meditation Error: Core  1 panic'ed (StoreProhibited). Exception was unhandled.
[12:14:35]
[12:14:35]Core  1 register dump:
[12:14:35]PC      : 0x400d4240  PS      : 0x00060c30  A0      : 0x800d21f5  A1      : 0x3ffb25a0
WARNING Decoded 0x400d4240: esphome::ssd1306_base::SSD1306::fill(esphome::Color) at W:\projects\active\esphome\data\.esphome\build\bootfail/src/esphome/components/ssd1306_base/ssd1306_base.cpp:334 (discriminator 2)
[12:14:35]A2      : 0x3ffb96a0  A3      : 0x00000000  A4      : 0x00000000  A5      : 0x3f400184
[12:14:35]A6      : 0x3f400f21  A7      : 0x3f408191  A8      : 0x00000000  A9      : 0x3ffb2580
[12:14:35]A10     : 0x00000200  A11     : 0x00000080  A12     : 0x00000024  A13     : 0x3f400184
[12:14:35]A14     : 0x3ffb2bb0  A15     : 0x00000000  SAR     : 0x00000004  EXCCAUSE: 0x0000001d
[12:14:35]EXCVADDR: 0x00000000  LBEG    : 0x400868bd  LEND    : 0x400868cd  LCOUNT  : 0xffffffed
[12:14:35]
[12:14:35]
[12:14:35]Backtrace:0x400d423d:0x3ffb25a00x400d21f2:0x3ffb25c0 0x400d2625:0x3ffb25e0 0x400d416a:0x3ffb2600 0x400d6ae1:0x3ffb2620 0x400d6ace:0x3ffb2640 0x400f9bf7:0x3ffb2660 0x400f9c2b:0x3ffb2680 0x400d6b63:0x3ffb26a0 0x400d1b12:0x3ffb26c0 0x400d1e0d:0x3ffb26f0 0x400d1de2:0x3ffb2710 0x400d1e14:0x3ffb2740 0x400d1e28:0x3ffb2760 0x400d69a3:0x3ffb2780 0x400d4a4e:0x3ffb27d0 0x400d6c56:0x3ffb2800 0x400d985d:0x3ffb2820
WARNING Found stack trace! Trying to decode it
WARNING Decoded 0x400d423d: esphome::ssd1306_base::SSD1306::fill(esphome::Color) at W:\projects\active\esphome\data\.esphome\build\bootfail/src/esphome/components/ssd1306_base/ssd1306_base.cpp:334 (discriminator 2)
WARNING Decoded 0x400d21f2: esphome::display::Display::clear() at W:\projects\active\esphome\data\.esphome\build\bootfail/src/esphome/components/display/display.cpp:16
WARNING Decoded 0x400d2625: esphome::display::Display::do_update_() at W:\projects\active\esphome\data\.esphome\build\bootfail/src/esphome/components/display/display.cpp:508
WARNING Decoded 0x400d416a: esphome::ssd1306_base::SSD1306::update() at W:\projects\active\esphome\data\.esphome\build\bootfail/src/esphome/components/ssd1306_base/ssd1306_base.cpp:230
WARNING Decoded 0x400d6ae1: std::_Function_handler<void (), setup()::{lambda()#2}>::_M_invoke(std::_Any_data const&) at W:\projects\active\esphome\data\.esphome\build\bootfail/bootfail.yaml:66
 (inlined by) _M_invoke at c:\users\jimmy\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\bits/std_function.h:297
WARNING Decoded 0x400d6ace: std::function<void ()>::operator()() const at c:\users\jimmy\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\bits/std_function.h:687
 (inlined by) esphome::LambdaAction<>::play() at W:\projects\active\esphome\data\.esphome\build\bootfail/src/esphome/core/base_automation.h:174
WARNING Decoded 0x400f9bf7: esphome::Action<>::play_complex() at W:\projects\active\esphome\data\.esphome\build\bootfail/src/esphome/core/automation.h:125
WARNING Decoded 0x400f9c2b: esphome::ActionList<>::play() at W:\projects\active\esphome\data\.esphome\build\bootfail/src/esphome/core/automation.h:203
WARNING Decoded 0x400d6b63: esphome::Automation<>::trigger() at W:\projects\active\esphome\data\.esphome\build\bootfail/src/esphome/core/automation.h:241
 (inlined by) esphome::Trigger<>::trigger() at W:\projects\active\esphome\data\.esphome\build\bootfail/src/esphome/core/automation.h:98
 (inlined by) esphome::binary_sensor::PressTrigger::PressTrigger(esphome::binary_sensor::BinarySensor*)::{lambda(bool)#1}::operator()(bool) const at W:\projects\active\esphome\data\.esphome\build\bootfail/src/esphome\components\binary_sensor/automation.h:26
 (inlined by) std::_Function_handler<void (bool), esphome::binary_sensor::PressTrigger::PressTrigger(esphome::binary_sensor::BinarySensor*)::{lambda(bool)#1}>::_M_invoke(std::_Any_data const&, bool&&) at c:\users\jimmy\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\bits/std_function.h:297
WARNING Decoded 0x400d1b12: std::function<void (bool)>::operator()(bool) const at c:\users\jimmy\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\bits/std_function.h:687
 (inlined by) esphome::CallbackManager<void (bool)>::call(bool) at W:\projects\active\esphome\data\.esphome\build\bootfail/src/esphome/core/helpers.h:492
 (inlined by) esphome::binary_sensor::BinarySensor::send_state_internal(bool, bool) at W:\projects\active\esphome\data\.esphome\build\bootfail/src/esphome/components/binary_sensor/binary_sensor.cpp:41
WARNING Decoded 0x400d1e0d: esphome::binary_sensor::Filter::output(bool, bool) at W:\projects\active\esphome\data\.esphome\build\bootfail/src/esphome/components/binary_sensor/filter.cpp:17
WARNING Decoded 0x400d1de2: esphome::binary_sensor::Filter::input(bool, bool) at W:\projects\active\esphome\data\.esphome\build\bootfail/src/esphome/components/binary_sensor/filter.cpp:25
WARNING Decoded 0x400d1e14: esphome::binary_sensor::Filter::output(bool, bool) at W:\projects\active\esphome\data\.esphome\build\bootfail/src/esphome/components/binary_sensor/filter.cpp:19
WARNING Decoded 0x400d1e28: std::_Function_handler<void (), esphome::binary_sensor::DelayedOnFilter::new_value(bool, bool)::{lambda()#1}>::_M_invoke(std::_Any_data const&) at W:\projects\active\esphome\data\.esphome\build\bootfail/src/esphome/components/binary_sensor/filter.cpp:42
WARNING Decoded 0x400d69a3: std::function<void ()>::operator()() const at c:\users\jimmy\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\bits/std_function.h:687
 (inlined by) esphome::Scheduler::call() at W:\projects\active\esphome\data\.esphome\build\bootfail/src/esphome/core/scheduler.cpp:234
WARNING Decoded 0x400d4a4e: esphome::Application::loop() at W:\projects\active\esphome\data\.esphome\build\bootfail/src/esphome/core/application.cpp:69
WARNING Decoded 0x400d6c56: loop() at W:\projects\active\esphome\data\.esphome\build\bootfail/bootfail.yaml:57
WARNING Decoded 0x400d985d: loopTask(void*) at C:/Users/jimmy/.platformio/packages/[email protected]/cores/esp32/main.cpp:50
[12:14:35]
[12:14:35]
[12:14:35]
[12:14:35]
[12:14:35]ELF file SHA256: 0000000000000000
[12:14:35]
[12:14:35]Rebooting...
[12:14:35]ets Jun  8 2016 00:22:57
[12:14:35]
[12:14:35]rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[12:14:35]configsip: 0, SPIWP:0xee
[12:14:35]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[12:14:35]mode:DIO, clock div:2
[12:14:35]load:0x3fff0030,len:1184
[12:14:35]load:0x40078000,len:13132
[12:14:35]load:0x40080400,len:3036
[12:14:35]entry 0x400805e4
[12:14:35][I][logger:156]: Log initialized
[12:14:35][I][app:029]: Running through setup()...
[12:14:35][I][i2c.arduino:218]: Performing I2C bus recovery
[12:14:35][C][ssd1306_i2c:010]: Setting up I2C SSD1306...
[12:14:35][I][app:062]: setup() finished successfully!
[12:14:35][D][binary_sensor:034]: 'rotary_encoder_btn': Sending initial state OFF
[12:14:35][I][app:100]: ESPHome version 2024.5.2 compiled on May 24 2024, 12:13:53
[12:14:35][C][logger:185]: Logger:
[12:14:35][C][logger:186]:   Level: DEBUG
[12:14:35][C][logger:188]:   Log Baud Rate: 115200
[12:14:35][C][logger:189]:   Hardware UART: UART0
[12:14:35][C][i2c.arduino:071]: I2C Bus:
[12:14:35][C][i2c.arduino:072]:   SDA Pin: GPIO16
[12:14:35][C][i2c.arduino:073]:   SCL Pin: GPIO17
[12:14:35][C][i2c.arduino:074]:   Frequency: 800000 Hz
[12:14:35][C][i2c.arduino:086]:   Recovery: bus successfully recovered
[12:14:35][I][i2c.arduino:096]: Results from i2c bus scan:
[12:14:35][I][i2c.arduino:102]: Found i2c device at address 0x3C
[12:14:36][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'rotary_encoder_btn'
[12:14:36][C][gpio.binary_sensor:016]:   Pin: GPIO19
[12:14:36][C][ssd1306_i2c:023]: I2C SSD1306
[12:14:36][C][ssd1306_i2c:023]:   Rotations: 0 °
[12:14:36][C][ssd1306_i2c:023]:   Dimensions: 128px x 32px
[12:14:36][C][ssd1306_i2c:024]:   Address: 0x3C
[12:14:36][C][ssd1306_i2c:025]:   Model: SSD1306 128x32
[12:14:36][C][ssd1306_i2c:027]:   External VCC: NO
[12:14:36][C][ssd1306_i2c:028]:   Flip X: YES
[12:14:36][C][ssd1306_i2c:029]:   Flip Y: YES
[12:14:36][C][ssd1306_i2c:030]:   Offset X: 0
[12:14:36][C][ssd1306_i2c:031]:   Offset Y: 0
[12:14:36][C][ssd1306_i2c:032]:   Inverted Color: NO
[12:14:36][C][ssd1306_i2c:033]:   Update Interval: 0.050s
