I’m having an issue integrating Ollama running on my PC (with an RTX a4000) with Home Assistant running on my Qnap NAS using a VM.
Ollama is installed on my PC and I can access HA on my PC as well. There is a virtual switch on my NAS allowing for the Home Assistant Virtualization Station to be accessed by my PC.
When I try the Ollama integration in HA, I type in my PC’s IP address 192.168.XX.XX:11434 and get the following message: “Invalid hostname or IP address”
Things I’ve tried:
- made sure Windows Firewall and NAS firewall aren’t blocking port 11434
- added
OLLAMA_HOST=0.0.0.0to my Windows system variables - enabled “expose Ollama to the network” in Ollama settings
Unfortunately, nothing worked so far.
Any ideas, community?
Thank you in advance.
