Hello
I just setup new instalation of OMV 5 on Debian 10. I also made clean Home Assistant installation in Docker. Then I configured Letsencrypt Addon and NGINX Addon to be able to access my Home Assistant with my sub-domain: https://home.example.com
Everything works fine. But now I would like to install NextCloud on my OMV 5 and configure it to work from sub-domain https://cloud.example.com
The problem is I cannot find in /etc/nginx/ any info about home assistant and if I would like to start NextCloud it fails because it works on same port with Home Assistant (listen 443/80).
I can stop NGINX Addon in Home Assistant and restart nginx service in ssh, in this case my nextcloud will work fine, but my home assistant is not accessible from external network. If I start Nginx Addon in HA - I can access from my subdomain, but cloud is off…
Is there any guide or example how can I setup it?
