On at boot ESPhome Sonoff pow
My Sonoff pow is working great with ESPHome and Hassio but I want to switch it on while booting after power failure!
Is this possible?
Regards.
Use the on boot event:
thnx, looks like it’s working!
Can you share ESPHome configuration for SonOff Pow ?
This is my config:
esphome:
  platform: ESP8266
  board: esp01_1m
  on_boot:
  - switch.turn_on: relay
wifi:
  ssid: "??"
  password: "??"
# Enable logging
logger:
  baud_rate: 0
  level: verbose
# Enable Home Assistant API
api:
  password: '??'
ota:
  password: '??'
uart:
  rx_pin: RX
  baud_rate: 4800
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO0
      mode: INPUT_PULLUP
      inverted: True
    name: "Sonoff POW 01 Button"
    on_press:
      - switch.toggle: fakebutton
switch:
    name: "Sonoff POW 01 Relay"
    optimistic: true
    turn_on_action:
    - light.turn_on: led
    turn_off_action:
    - switch.turn_off: relay
    - light.turn_off: led
  - platform: gpio
    pin: GPIO12
output:
  - platform: esp8266_pwm
    pin:
      number: GPIO13
      inverted: True
light:
  - platform: monochromatic
#    name: "Sonoff POW 01 Blue LED"
    output: pow_blue_led
  - platform: wifi_signal
    name: "Sonoff POW 01 WiFi Signal"
    update_interval: 60s
  - platform: uptime
    name: "Sonoff POW 01 Uptime"
  - platform: cse7766
    update_interval: 2s
    current:
      name: "Sonoff Pow 01 Current"
    voltage:
      name: "Sonoff Pow 01 Voltage"
    power:
      name: "Sonoff Pow 01 Power"
@tom_l will you please help me out in this please. i have a RGBW bulb running esphome how can i set fixed color and brightness on boot? for example on boot set color to red and brightness 80%
this how my config
esphome:
  platform: ESP8266
  board: esp01_1m
  on_boot:
wifi:
  ssid: "xxxx"
  password: "xxxxxxxx"
# Enable logging
logger:
api:
ota:
    name: "WiFi Signal h801light"
  - platform: uptime
    name: "Uptime h801light"
#RGBWarm
output:
    pin: 12
    frequency: 1000 Hz
    pin: 13
    frequency: 1000 Hz
    pin: 15
    frequency: 1000 Hz
    pin: 14
    frequency: 1000 Hz
light:
  - platform: rgbw
    red: pwm_r
    green: pwm_g
    blue: pwm_b
    white: pwm_w
I’ve never used this service but from reading the docs I think you need:
esphome:
  platform: ESP8266
  board: esp01_1m
  on_boot:
    then:
      - light.turn_on:
          red: 80%
          green: 0%
          blue: 0%
          white: 0%
also
light:
  - platform: rgbw
    id: "h801_light"     ###  <------ Think this is required, id may be generated from Name: though, not sure. Can't hurt to add it
    red: pwm_r
    green: pwm_g
    blue: pwm_b
    white: pwm_w
As I said in the comment above, I’m not sure if a device id defaults to the name (but with all lower case letters and with spaces replaced by _ ) or not. You could experiment with and without the id: in the light config and see if it still works. Either way it should not hurt to specify the id and a name.
i will try this out when i get back home thank you.
@tom_l thank you so much it worked.
Did you need the light id, or just the name?
i had to use id without id he gives an error " id is required option [for light.turn on]"
