On_boot not working with addressable LED strip
esphome:
  on_boot:
    - light.addressable_set:
        red: 50%
        green: 0
        blue: 0
        white: 0
esp32:
  board: nodemcu-32s
logger:
web_server:
  port: 80
<<: !include _base.yaml
light:
  - platform: esp32_rmt_led_strip
    rgb_order: GRB
    pin: GPIO2
    num_leds: 10
    rmt_channel: 1
    chipset: SK6812
    is_rgbw: true
    internal: true
when the system starts up with the above config, none of the LEDs are on, even though I’d expect them to be.
  on_boot:
    - light.turn_on: status_light
        red: 50%
        green: 0
        blue: 0
        white: 0
With the above changes, I see all the LEDs light up red for a fraction of a second before going white. This is the opposite of what I expect to happen!
When I open up the web console, I can confirm that the color is set to white: “Keeping current color mode White for call without color mode”, and this is not a color channel misconfiguration.
Any ideas why this is behaving so oddly?
What does the documentation say about using RGB % values in regards to brightness? Ya know, the Docs are a super helpful place to find answers and learn this stuff.
You also need to read the part that explains what light.addressable_set: is for and what the difference is between light.addressable and light.turn_on/turn_off.
These are used for 2 specific purposes and they do 2 different things.
Please read the first code snippet closely, particularly around on_boot. With only the light.addressable_set and no light.turn_on, things behave even more poorly.
I’m aware of the excellent documentation and have read it closely but unfortunately I don’t see how it resolves my issue.
What is light.addressable_set for?
Try raising the on boot priority to 800. Default (as you have not specified anything) is 600.
See: ESPHome Core Configuration — ESPHome
No brightness defined.
esphome:
  on_boot:
        red: 50%
        green: 0
        blue: 0
        white: 0
esp32:
  board: nodemcu-32s
logger:
web_server:
  port: 80
light:
    rgb_order: GRB
    pin: GPIO2
    num_leds: 10
    rmt_channel: 1
    chipset: SK6812
    is_rgbw: true
    internal: true
light.addressable is for controlling a range of led’s just like it sais and you couldn’t find some how.
You also have no range defined so in that case you need to use light.turn_on
This is the part I was trying to get you to find but, you missed this big information box somehow. 50% Red only sets the % Red, not the brightness. You have to configure the brightness in addition to the color.
Does light.addressable_set work as expected outside of on_boot?
I’m wondering if this could be a timing issue, e.g. you are trying to turn on the light whole the component is still initialized?
on_boot has an additional parameter priority which can be used to set the execution order.
Yeah I mentioned that already.
800 segfaults due to the light not being initialized yet, which makes sense to me given the docs. priority: 0 doesn’t seem to help either. I don’t have anything else in my config affecting this light, so I don’t think this is it.
when range_to and range_from are left blank, they default to all LEDs in the strip
Oh, I did miss that! That’s going to be helpful in a moment, but in this case it shouldn’t matter. I should just be seeing red at full brightness.
what seems to have solved the problem is the following, particularly the transition_length: 0s, and the very small initial color value. It seems like the transition from the first command was overriding the second
    - light.turn_on:
        red: 0
        green: .1
        blue: 0
        white: 0
        red: 100%
        green: 0
        blue: 0
The reason I do it this unusually way is because this is not my real problem, but a simplification of what I’m trying to do. Here’s where I’ve finally ended up:
This turns the color LEDs “on”, but then stops anything from being shown on them:
esphome:
  on_boot:
  - light.turn_on:
      red: 0
      green: .1
      blue: 0
      white: 0
      red: 0
      green: 0
      blue: 0
Then, later on, I use these LEDs as an indicator:
output:
  - platform: gpio
    pin: GPIO25
  - platform: gpio
    pin: GPIO22
  - platform: gpio
    pin: GPIO17
  - platform: gpio
    pin: GPIO21
    type: float
    write_action:
      - lambda: |-
          id(fan_low).turn_off();
          id(fan_mid).turn_off();
          id(fan_high).turn_off();
          id(fan_turbo).turn_off();
          auto light = ((AddressableLight*)id(status_light).get_output());
          for (int i = 6; i <= 9; i++) {
            light->get(i).set(Color::BLACK);
          if (state < 0.24) {
          } else if (state < 0.26) {
            id(fan_low).turn_on();
            light->get(6).set(Color(255,0,0,0));
          } else if (state < 0.51) {
            id(fan_mid).turn_on();
            light->get(7).set(Color(255,0,0,0));
          } else if (state < 0.76) {
            id(fan_high).turn_on();
            light->get(8).set(Color(255,0,0,0));
          } else {
            id(fan_turbo).turn_on();
            light->get(9).set(Color(255,0,0,0));
          light->schedule_show();
Thank you all for the help and the suggestions!
So move it up a bit. You started at 600. You know it can’t be 800. So try 700.
This configuration works well with addressable LEDs (ws2812x, neopixelbus) indicating the start and end of the boot process:
esphome:
  on_boot:
    - priority: 600
      then:
        - light.turn_on:
            brightness: 100%
            red: 100%
            green: 0%
            blue: 0%
    - priority: -100
      then:
        - delay: 3s
        - light.turn_on:
            effect: "1-green"
            brightness: 15%
I don’t know if this helps, but I find it cleaner to put the code into a script and just call the script on boot:
esphome:
  on_boot:
    priority: -100.0
    then:
      - script.execute: test_trashbin
