On_boot time condition check
Hallo!
I want to check time on boot and if time after 7 and before 22 switch relays on or off
 on_boot:
    priority: -100.0
    then:
      - if:
          condition:
            and:
              - lambda: |-
                  return id(sntp_time).now().hour > 7;
              - lambda: |-
                  return id(sntp_time).now().hour < 22;
          then:
            - switch.turn_on: relay1
            - switch.turn_on: relay2
          else:
            - switch.turn_off: relay1
            - switch.turn_off: relay2
if I reboot esp at example 07:20 relays are off
I have 2 questions:
  1. How can i define time interval in hours and minutes on boot?
  2. If i restart ESP by switch from HA - on_boot automation works good
    but if restart ESP by turning power off and on - on_boot automation does not work
any help?
peace!
Could you use on_time: instead?
I use on_time: to switch relays on and off at 7 and 22.
  - platform: sntp
    on_time:
      - seconds: 0
        minutes: 0
        hours: 7
        days_of_week: SUN-SAT
        then:
I need to check time interval then esp boots after power outage… and switch relays according to this interval on or off
If I understand correctly what you are trying to achieve, you want the realys to go to the state they were before the reboot.
If so, have you tried using restore_mode in your switch config?
Or use this: Restore from flash.
imagine the situation:
My relays turns on at 7.00 and turns off at 22.00.
Let’s say that now time is 21.00 (relays are on) and the power suddenly turned off(power outages).
And then turned on at 23.00(relays should already must be off)
So I need to verify what time is now after esp boot up
and if time between 7.00 and 22.00 - turn relays on. If no - turn off
I think explained clearly
sorry for my English)
On boot, the device won’t know what the time is straight away. I guess you’ve tried to work around that with your priority: -100.0, but the docs say:
Before the ESP has connected to the internet and can get the current time the date will be January 1st 1970. So make sure to check if .is_valid() evaluates to true before triggering any action.
Maybe that’s the issue? When you restart via the reset button, it may remember the time, but not through a power cycle. Is there anything in the logs that might help?
solved 2-nd problem with
on_boot:
    priority: -100.0
    then:
      - delay: 4s
but 1-st problem is actual
1-st problem solved
respect to John
Continuing the discussion from time condition check:
  time:
    - platform: homeassistant
    - platform: sntp
  binary_sensor:
    device_class: light
  - platform: gpio
    pin:
      number: D5
      mode: INPUT_PULLUP
      inverted: yes
    device_class: motion
    on_press:
      then:
        - script.execute: scrl_day_night
        - if:
            condition:
              binary_sensor.is_on: bs_sun
            then:
              - logger.log: "Day, Day, Day !!!!!!!!!!!!!!!!!!!!!!!!"
              # - script.execute: scrl_day
            else:
              - logger.log: "Night, Night, Night, !!!!!!!!!!!!!!!!!!!!!!!!"
              # - script.execute: scrl_night
  script:
    - id: scrl_day_night
      then:
        - if:
            condition:
              and:
                - lambda: |-
                - lambda: |-
                    return id(sntp_time).now().hour < 23;
            then:
              # - logger.log: "YESSSSS !!!!!"
              - lambda: |-
                    id(bs_sun).publish_state(true);
            else:
              # - logger.log: "NOOOO !!!!!"
              - lambda: |-
                    id(bs_sun).publish_state(false);
Проверка через ‘script’.
Извините, я не знаю Английский.
Google brought me here but there was no clear solution just hints. I eventually got it working with this code
esphome:
  friendly_name: Front Porch
  # Ensure correct switch state on boot based on current time
  # Useful for handling power cycling
  on_boot:
    priority: -100
    then:
      - delay: 4s
      - if:
          condition:
            lambda: |-
              auto current_time = id(homeassistant_time).now();
              int hour = current_time.hour;
              return hour > 19;
          then:
            - switch.turn_on: porch_cat_door
      - if:
          condition:
            lambda: |-
              return hour < 11;
          then:
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "***redacted***"
ota:
  - platform: esphome
    password: "***redacted***"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Front-Porch Fallback Hotspot"
captive_portal:
web_server:
  port: 80
switch:
  - platform: gpio
    pin: GPIO5
    inverted: False
    restore_mode: RESTORE_DEFAULT_OFF
  - platform: gpio
    name: "Garden Watering"
    pin: GPIO4
    inverted: False
    # When the switch turns on, start the 60-minute timer script
    on_turn_on:
      - script.execute: tap_timer_script
    # When the switch turns off, stop the timer script
    on_turn_off:
      - script.stop: tap_timer_script
# Script to handle the timer with reset functionality
script:
  - id: tap_timer_script
    then:
      - delay: 30s  # 60 minutes
      - logger.log: "60-minute timer expired. Turning off the switch."
      - switch.turn_off: garden_tap
time:
  - platform: homeassistant  # Use Home Assistant time, or use 'sntp' for internet time
    # Schedule to turn on the switch at 7 PM every day
    on_time:
      - seconds: 0
        minutes: 0
        hours: 19  # 7 PM in 24-hour format
        then:
          - logger.log: "Turning on the switch at 7 PM"
    # Schedule to turn off the switch at 6 AM every day
      - seconds: 0
        minutes: 0
        hours: 11  # 6 AM in 24-hour format
        then:
          - logger.log: "Turning on the switch at 6 AM"
          - switch.turn_off: porch_cat_door
