On door open, turn on, then off a set of lights filtered in template
Here’s what I’m attempting to do: When I open a door, I want to look at the state of three lights, if any of them are off, I want to turn them on, then off 5 min later (leaving any of the three on that were on to begin with).
What I have works to select only the lights that were off, but I’m not sure how to ‘remember’ which set of lights I turned on so that I only turn those off.
Here’s what I have so far:
- alias: Dog Potty Lights
    - platform: state
      entity_id: binary_sensor.back_door
      to: 'on'
  condition:
    condition: or  # 'when dark' condition: either after sunset or before sunrise
    conditions:
      - condition: sun
        after: sunset
      - condition: sun
        before: sunrise
    - service: switch.turn_on
      data_template:
        entity_id: >
          {% set my_list = [states.switch.garage_outside_light,
                            states.switch.back_door_light,
                            states.switch.patio_lights]
          | rejectattr('state','equalto','on')
          | map(attribute='entity_id' )
          | join(', ') %}
          {{my_list}}
    - delay: 0:05:00
    - service: switch.turn_off
      data_template:
        entity_id: {{ my_list }}
That last line is the part that doest work because my_list is no longer defined.
I’m relatively new to HA, so any help would be appreciated!
Use input_booleans?
I figured out a way using scripts. First, my automation looks like this:
    - platform: state
      to: 'on'
  condition:
    conditions:
      - condition: sun
        after: sunset
      - condition: sun
        before: sunrise
      service: script.timed_lights
      data_template:
        delay: '00:05:00'
        # pass a list of lights, rulling out the ones that are already on
        lights: >
          {{ [states.switch.garage_outside_light,
          | join(', ') }}
This makes a list and puts it in the variable lights and it puts a desired delay time in delay, which are passed to my script timed_lights which looks like so:
timed_lights:
  sequence:
      data_template:
        entity_id: "{{lights}}"
    - delay: "{{delay}}"
      data_template:
