On ESPHome with an ESP8266 i have a remote waterpump connected to a binary_sensor where it shows me the status of the pump ‘ON or OFF’
I try to figured out how to count the ‘ON/OFF’ status over 24hrs and the total ‘ON’ time in that period and to display the results but I was not successful.
I need help for this problem.
It’s a lot easier to do in home assistant with the history stats sensor:
Is it possible to program it in ESPhome (ESP8266) not in configuration.yaml?
You write a simple yaml configuration for each sensor/device you want to attach to the ESP and ESPHome compiles the result into an executable file.
You also have the option of including C code as lambdas.
There is provision to include conditional automations on the device. So it can run completely autonomously if you wish.
I did this for the already with several sensors on an ESP32 and ESP8266 there is my working setup. I want to expand the features on
- **platform: gpio**
** name: "Wasserpumpe Pin 19"**
** pin: 19**
to record length of ON and total time. But maybe you have a sample available to do it because I am a newbie and not familiar with lambda and C programming.
switch:
- platform: restart
- platform: shutdown
#wifi signal
- platform: wifi_signal
update_interval: 6s
#bme280
- platform: bme280
temperature:
pressure:
humidity:
address: 0x76
update_interval: 6s
#battery
- platform: adc
pin: 34
attenuation: 11db
name: "Solarpanel 24V Pin34 "
filters:
- multiply: 20
update_interval: 6s
- platform: adc
pin: 35
attenuation: 11db
name: "Akku 24V Pin35"
filters:
- multiply: 10
update_interval: 6s
- platform: adc
pin: 32
attenuation: 11db
name: "Solarpanel 12V Pin32"
filters:
- multiply: 10
update_interval: 6s
- platform: adc
pin: 33
attenuation: 11db
name: "Akku 12V Pin 33"
filters:
- multiply: 10
update_interval: 6s
binary_sensor:
- platform: gpio
name: "Reservoir voll Pin 16"
pin: 16
- platform: gpio
name: "Reservoir low Pin 17"
pin: 17
- platform: gpio
name: "Haus Stromversorgung Pin 18"
pin: 18
- platform: gpio
pin: 19
- platform: gpio
name: "Werkstatt Pin 5"
pin: 5
- platform: gpio
name: "Wechselrichter Pin 4"
pin: 4
- platform: status
Just do it in home assistant. Use the tools you have. Easy as anything.
