Agreed.
I’m working on walk-through that I’ll submit as a PR at some stage. Hoping to make it as easy as possible.
Agreed.
All of that + many users have sbc like b3+, b4 or slightly better sbc that doesn’t have ability to run an hypervisor easly, and maybe an sbc can be used for anything else than just HA, like a webserver, to control a device, a serial or anything a person want to do with that stuff, but not tied to an OS that you have no “control of”.
And the worst thing is that for some users the only answer is “proxmox it” and just don’t listen to the problem.
But i’m glad that someone else have focus on it.
Since the poll is buried in the middle of the thread and hard to find here is the final tally
BUT…remember to vote in the other poll, too, if you haven’t already: How did you install Home Assistant?
I have always known that to be the case, but we still don’t pay for HA.
Hi all.
I am currently running homeassistant in venv under hassbian (old config, i know).
i tried the hassos installation on my new raspberry 4 and it works well but, i can not use my iscsi settings on my synology nas as i do with the old venv one.
This is why i hope they will continue to support supervised version wich seems to be the only way for me to go for using hassio (all thoses docker container together) on an iscsi connection.
The main reason is to use the sd card only for the boot part and let all the linux/docker/databases, etc on the iscsi connection.
This is the exact way I have been using HA since I moved from my Pi. This is ideal for me as the PC running ubuntu displays my BlueIris cameras in the browser on a display above my normal PC getting dual use out of the HA server. Since most of my network/home automation equipment is here, its been ideal since the start.
The poll is nice but polls here are unfortunately highly likely to be skewed by self-selection bias.
I’m concerned about fairness here for the core developers, and other users not affected by this hot issue.
For details Please see my comment at https://community.home-assistant.io/t/how-did-you-install-home-assistant/196300/63?u=carver
No need to worry about the core developers. It’s unlikely the poll’s results will influence decisions. They will be acquiring the data they need via a revised updater component in version 0.110.
Anyone who is using the Supervised version and wants their “vote” to be counted, ensure you have not disabled the updater component. If you are using the default_config option (it’s enabled on all new installations) you’re fine. If you disabled it and have cherry-picked the options it represents, ensure updater is enabled.
Let’s hope they share that data!
To my knowledge, they never did in the past, at least not officially. I believe I recall Paulus mentioning it informally in a podcast about 1 if not 2 years ago. Hassio on RPI represented just over half of all installations (at the time).
I would think that, in the interests of better communication, they should share the results this time. I recall someone suggested they create a stats page revealing the installation types . After all, it is community data being harvested so it ought to be shared with the community.
Thoroughly agree @123
I’m also sad about that decisicon, as I am also running Home Assistant Supervised on my Ubuntu server which is running 24/7 anyway, so if it’s not necessary, I don’t want to run HA in a virtual machine or buy a Raspberry Pi just for HA.
For me, the generic installation is / was the perfect solution
At the beginning, when I compared different home automation systems (like HA, OpenHab etc.), I tested all of them by installing them on Ubuntu. If this method is not available anymore, the barrier of installing and testing HA will get higher, which would be really sad for possible future members of this community.
You can still run HA core on ubuntu, via venv or docker.
Ha core is not the solution, if you are on supervised
And supervised is not necessary to automate your home. It is useful for addons, but all software that can be added via addons can be added in your OS or via docker, depending on your preference. This is NOT the end of the world for people who don’t want to run a VM.
So +60% or more users are on supervised, why not deprecate ha core?
Ummmmm, without core the supervisor has nothing to run. Apart from addons.
Also, I call rubbish on that. There have been 2 polls, both self selecting, and both surveying a TINY proportion of total user.
For me, the main advantages of HA compared to other competitors are the Supervisor-Functions (easy updates, backups/restores and add-on-installation), so if these advantages are not available anymore on Ubuntu, HA would loose its charme for me
Understood, but what would you use then?
Backups are achieved super easily, if you run ubuntu anyway you know how to run rsync or tar.
If you run ubuntu already, you can probably write a script run the three necessry commands to update.
I like the supervisor too. I like the addons too. But they are by no means essential to running home automation.
