Somewhere on this forum i found the solotion to add a ev1527 doorsensor.
I added the yalm to the configuration yaml, and it looks like the code set the input_boolean to on or off.
With this input boolean i want to turn on a light, but i can not manage it.
I think i am doing something wrong, but don’t know what?
Can somebody help?
This is the code i have placed in the configuration.yaml
binary_sensor:
- platform: rflink
devices:
ev1527_0e0fb0_0a:
name: Deur Hal Open
off_delay: 1
ev1527_0e0fb0_0e:
name: Deur Hal Closed
off_delay: 1
input_boolean:
my_door_sensor_hal:
And this code i have placed in the automatation.yaml
alias: update_my_door_sensor_hal
description: ""
- platform: state
entity_id: binary_sensor.deur_hal_open
to: "on"
- platform: state
entity_id: binary_sensor.deur_hal_closed
to: "on"
- service: >-
input_boolean_turn_{% if trigger.to_state.object_id.split('_')[2] ==
'0a'%}on{%else%}off{%endif%} entity_id: input_boolean.my_door_sensor_hal
When i open the door i can see that the input_boolean.my_door_sensor_hal is updated.
then i have to make an automation which see that the boolean is updated an than turn on a light.
I have made this automation, but it doesn’t work.
alias: lamp aan
description: ""
- platform: state
entity_id:
- input_boolean.my_door_sensor_hal
to: "on"
- service: light.turn_on
entity_id: light.verlichting_hal_toilet
data: {}
When i execute this uitomation by hand the lights turn on, but it is not executed by the first automation.
Does somebody what is wrong, or what i have to do?
