Dozent
(Dozent)
October 18, 2023, 6:56pm
1
I’m trying this configuration, but I can’t turn off the Apple TV
- id: off_tv
alias: Off TV
description: offTV
- platform: device
type: turned_off
entity_id: remote.apple_tv_4k
domain: remote
condition: []
- wait_for_trigger:
- platform: device
type: turned_off
entity_id: switch.apple_tv_4k
domain: switch
mode: single
The Apple TV cannot be turned off. She will go to stamby after a few minutes.
Dozent
(Dozent)
October 18, 2023, 9:14pm
3
Can be turned off with two keys home and select. But I don’t know how to programmatically hold down the home key for 2 seconds
lounge_appletv_poweroff:
alias: Power off TV
sequence:
- service: remote.send_command
delay_secs: 3
command:
- home
- select
This is from a lovelace card, not an automation, but the media_player.turn_off service call works with apple TV.
hold_action:
action: call-service
service: media_player.turn_off
device_id:
- #your apple tv's device id.
It’ll go to ‘standby’ but that is off. Also, your code won’t turn it off, you’re waiting for a trigger, not taking an action.
Floo
October 19, 2023, 9:44am
5
There is the option home_hold that you can use.
Check the docs for more info about it.
apple_tv_sleep:
alias: "Make the Apple TV sleep"
sequence:
entity_id: remote.lounge_appletv
delay_secs: 1
command:
- home_hold
- select
- service: media_player.turn_off
entity_id: media_player.lounge_appletv
dMopp
(dMopp)
October 19, 2023, 11:34am
6
This is the way over Bluetooth Remote with tvOS17:
goldbingo
(Goldbingo)
January 3, 2024, 12:28pm
7
“home_hold” trick doesn’t work for current tvOS 17.2 neither.
Instead, the “Sleep Now” item in Settings app will do the trick.
- service: media_player.select_source
entity_id: media_player.appletv
source: Settings
entity_id: remote.appletv
delay_secs: 0.7
hold_secs: 0
command:
- menu
- menu
- menu
- menu
- menu
- top_menu
source: Settings
num_repeats: 12
delay_secs: 0.7
hold_secs: 0
command: down
command: select
The media_player: Turn Off service works by itself, no need to pretend to manipulate the remote control.
