On/Off or Toggle Control with Scene Options (NFC & Triggers)
This automation blueprint provides a robust, universal controller optimized for NFC tags and custom triggers, while working wonderfully with buttons and switches. It gives you explicit control over On, Off, and Toggle actions, with seamless support for optional, multi-scene presets that fire immediately after turning your target devices on.
Features
  • NFC-First Optimization: Designed to make tapping NFC tags around your home feel instantaneous and reliable.
  • Explicit Action Control: Choose whether the trigger executes an explicit Turn On, Turn Off, or smart Toggle behavior.
  • Optional Scene Presets: Select multiple scenes to apply automatically right after your target devices turn on.
  • Smart Toggle Logic: Automatically detects if your target devices are currently active. If anything is on, it shuts them down; if everything is off, it powers them up and applies your selected scenes.
  • Multi-Device Support: Control lights, switches, fans, or input booleans—individually or as a group.
Input Configuration Reference
Input Type Description
Triggers Trigger Selector Add your custom triggers here (NFC tags work brilliantly here!).
Target Entity Target Entity The lights, switches, fans, or input booleans to control.
Action Radio Buttons (Select) Choose what happens when triggered (Turn On, Turn Off, or Toggle).
Optional Scenes (Turn On Presets) Scene Entities (Multiple & Reorderable) Optional: Applied right after turning ON (or toggling on).
Pro Tips
  • NFC Placement: Place NFC tags near entryways, bedside tables, or desks to quickly toggle room states or activate your favorite mood lighting with a simple tap of your phone.
  • Scene Sequencing: If you select multiple optional scenes, Home Assistant will apply them in sequence right after the target devices wake up.
  • Off Action & Scenes: The Turn Off action (and the off phase of a toggle) only turns off your specified target devices; it does not explicitly deactivate scenes, as Home Assistant scenes are state presets rather than persistent running entities.
  • Group Control: Target a Home Assistant light or switch group to control an entire room’s worth of devices with a single NFC tap or button press.
Installation
Method 1: Click to Import (Easiest)
Click the badge below to import this blueprint directly into your Home Assistant instance:
Method 2: Manual Installation
  1. Download or clone the raw on_off_toggle_nfc_trigger_options.yaml file from this repository. on_off_toggle_nfc_trigger_options.yaml
  2. In your Home Assistant configuration directory, navigate to your blueprints folder (e.g., config/blueprints/automation/ufans123/).
  3. Paste the code into a file named on_off_toggle_nfc_trigger_options.yaml.
  4. Reload your automations or restart Home Assistant.
Method 3: Manual Installation using the Blueprints Dashboard (Easier)
  1. Copy the following URL…
https://github.com/ufans123/home-assistant-blueprints/blob/main/on_off_toggle_nfc_trigger_options.yaml
  1. Navigate to your Home Assistant Blueprints Dashboard UI.
  2. In the bottom right corner click on the ‘Import blueprint’ button.
  3. Paste in the URL and follow the prompts.
Use Cases
Tap-to-Toggle Outdoor & Appliance Outlets
Scan an NFC sticker (e.g., a tag placed on a patio door or desk) to intelligently toggle a smart plug on or off (switch.geeni_patio_plugs_socket_2) without needing to launch the Home Assistant app.
Cross-Device Power Sync Triggers
Monitor standard entity state changes—such as powering on an office phone charger—to automatically trigger a target device elsewhere in the home (like turning on a bedroom charging plug).
NFC Room Ambiance Activation
Tap an NFC tag near a entryway or bedside table to power up room lights and instantly apply multi-scene presets (such as a relaxing evening or reading scene) in a single action.
